EOT mod pics???
Old Feb 28, 2009 | 11:27 AM
Brown Falcon's Avatar
Brown Falcon
EOT mod pics???
Anyone got them? I found a link that CoonHunterJoe put up but it won't go through...
Just need a how-to with pics of which wire to do, etc.
Old Feb 28, 2009 | 11:53 AM
Brown Falcon
Just found CoonhunterJoe's pics... so for the EOT mod I just need to put the 4.7k resistor inline with the green wire w/ red stripe?
Just want to be sure that's all it takes...
Old Feb 28, 2009 | 01:29 PM
Hussler's Avatar
Hussler
You can use either wire, whichever is easier to get to.
Old Feb 28, 2009 | 10:22 PM
c00nhunterjoe's Avatar
c00nhunterjoe
yup, what he said, the sensor is an "in and out", just a resistor, so it doesnt matter if you put the 4.7 before or after the sensor as long as its in there to modify the signal before it hits the pcm.
Old Mar 1, 2009 | 08:40 AM
Brown Falcon
Ok. Cool. If it stops raining today maybe I'll be able to get it done.
Old Mar 1, 2009 | 10:00 AM
crash1's Avatar
crash1
I'm alittle confused on the mods. theres a eot mod which is oil temp with the resister trick. then i think theres one for the fuel pres. censor too right which is a resister also.
Old Mar 1, 2009 | 11:55 AM
2 stroke man's Avatar
2 stroke man
i'm behind. whats the EOT do for ya?
Old Mar 1, 2009 | 02:58 PM
Hussler's Avatar
Hussler
Tells PCM that engine oil temperature is colder than actual and cause advance in timing.
Old Mar 1, 2009 | 03:07 PM
Brown Falcon
Looks like it finally stopped raining. Maybe I'll get it done today after all!
Old Mar 1, 2009 | 03:52 PM
tjbeggs's Avatar
tjbeggs
Yep changes the injection timing due to a perceived oil temperature difference. BUT nobody know how much it changes timing. And on a diesel changing timing can be dangerous cause that is the number one factor in cylinder pressures. Not a good mod IMO.
Old Mar 1, 2009 | 09:25 PM
2 stroke man
ya, Tim i agree, some things probably best left alone. Dad said the other day he couldnt imagine if my truck had to go to a mechanic or dealer for something. he said they'd never get sorted through all my Presidential Engineering
