Clicking under dash, wont start
Old Feb 27, 2009 | 12:49 PM
fuelit's Avatar
fuelit
Got a stumper, When turn key on, hear clicking under dash in center adn truck wont start. Found 2 relays and flasher there, replaced relays, still have problem. Truck will start when relays dont click. Realy bad when cold.
Old Feb 27, 2009 | 12:56 PM
superduty4x4's Avatar
superduty4x4
Batteries are taking a dump on you- have them tested. If one is bad, replace BOTH. If you only replace one, the old one will drag the new one down. Welcome to FTE!
Old Feb 27, 2009 | 02:24 PM
Ponyboychris's Avatar
Ponyboychris
Chase nailed it. I had the same issue. TWO new batteries and all is well.
Welcome to FTE.
Old Feb 27, 2009 | 02:30 PM
Pocket's Avatar
Pocket
Sounds like a battery issue to me too, especially when you mentioned that colder weather makes it worse. If you have one bad battery, then you only have a marginal amount of juice to crank the truck in ideal weather. In the winter time and in colder temps, all bets are off.
Old Feb 27, 2009 | 02:38 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
I had the same thing happen to me. I was wondering what the heck is all that crap ticking. 2 batteries later, good to go.
Old Feb 27, 2009 | 02:39 PM
Ponyboychris
Yes, I killed mine on a minus 5 degree day a couple of winter's ago.
Old Feb 27, 2009 | 03:16 PM
theenforcer's Avatar
theenforcer
i was just about to ask the exact question, i have a ford courier work ute and only drive my truck on the weekends now, the other day i stopped at the shops and turned the car off and it sounded like my indicators were on and flashing like crazy so i turned the key back on and it stopped but i had no power at all after turning the key off and on a couple of times it all came good. does this sound like the batterys are on there way out also.
i did check the batterys with a multimeter and one was a couple of volts lower than the other...
Old Feb 27, 2009 | 03:26 PM
miller_feed
I would clean the post on the batteries, and it also sounds like a grround problem.
Old Feb 27, 2009 | 05:16 PM
just another truck's Avatar
just another truck
Besides, you should check the voltage under a load. If it drops below 10.5 ( i believe) is when you get the clicking..
Old Feb 28, 2009 | 02:54 PM
theenforcer
it just seemed weird cause it has never given me a problem before ever, i'll give the batteries a clean and see how it goes.
when you say check under load, do you mean having the engine running with maybe the headlights and the A/C going.
Old Feb 28, 2009 | 03:03 PM
1996pwrstrk's Avatar
1996pwrstrk
Have someone start your truck while you check the voltage at the batteries.
Old Feb 28, 2009 | 03:19 PM
theenforcer
cool thanks dave i'll give it a go
jvjaj
1997 - 2003 F150
Nov 30, 2017 11:04 AM
jistrebe
Jul 19, 2016 12:56 PM
Onegnat
General Automotive Discussion
Jul 11, 2016 07:07 AM
jdogz1031
1997 - 2003 F150
Sep 18, 2012 07:07 PM
Moto52
13
Oct 7, 2011 08:17 PM
