egt guage install question
Old 02-28-2009, 02:11 PM
jjfl03psd4x4
jjfl03psd4x4 is offline
jjfl03psd4x4 is starting off with a positive reputation.
203 f350 4" exhaust. Where is the most practicle place to install the EGT probe. I am trying to figure out if I have to drill and tap the manifold, or if I can use the clamp provided with the probe. pros and cons to pre and post turbo install???
Also what kind of antifreeze are we supposed to use. I noticed today that my overflow is low.
Thanks again
Joe
Old 02-28-2009, 02:22 PM
Ford79's Avatar
Ford79
Ford79 is offline
Ford79 has much to be proud ofFord79 has much to be proud ofFord79 has much to be proud ofFord79 has much to be proud ofFord79 has much to be proud ofFord79 has much to be proud ofFord79 has much to be proud ofFord79 has much to be proud of
Most install the probe into the driver side manifold. Drill and tap. Some install in the up pipe with the clamp. Pre turbo is the place to install it, more acurate temp reading as to what the actual cylinder temps are. Post turbo might be easier to install, but not nearly as acurate.
As far as I know, the 2003 use gold coolant.
Old 02-28-2009, 03:48 PM
makomaker's Avatar
makomaker
makomaker is offline
makomaker is gaining momentum as a positive member of FTE.makomaker is gaining momentum as a positive member of FTE.
Absolutely install pre-turbo, might as well hang it out the window if you install post turbo. Drill and tap exhaust maniold driver's side, start w small bit and work up, new bits go thru it like butter. Use the recommended thread lock on the tip and it will be fine.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
