Door Rattling???
Old Feb 25, 2009 | 11:41 PM
Powerstroke-7.3's Avatar
Powerstroke-7.3
Door Rattling???
Hey guys, my passenger door on my 99 F250 4x4 is rattling. It is shut tight and still rattles. I have looked at all the strikers but i cant find any thing wrong. Any advice???
Old Feb 26, 2009 | 10:25 AM
Bergerson's Avatar
Bergerson
pull off door panel, super simple, takes all of 2 minutes, pull/pry off the door lock/window button trim, and light cover on door panel, two 8mm bolts i believe behind these two panels, pull/pry off black plastic piece in corner of window, lift up and pull out on door panel, it will come right off... inside, the window tracks have two bolts that hold them tight to the door, 10 mm i believe, mine were driving me crazy, i tightend them up and no more rattles... also the door lock arm can rattle too if it is not secured down with the plastic clips.. hope that helps
Old Feb 26, 2009 | 12:04 PM
DieselBeast01's Avatar
DieselBeast01
yep bergerson is right, I tightened all the components in my doors on monday.
Old Feb 26, 2009 | 12:05 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
and while your at it do the door seal mod with the tubing...
Old Feb 26, 2009 | 05:04 PM
Powerstroke-7.3
Door Rattling
Hey guys. Thanks for the advice. I did everything that bergerson said and nothing was loose. Im glad i tore into it though because i found other things that i fixed. If you have any other ideas please let me know. Thanks
Old Feb 26, 2009 | 06:09 PM
megawatt00's Avatar
megawatt00
With the door closed can you "push" it and feel it loose?
Old Feb 26, 2009 | 07:22 PM
guitarpicr's Avatar
guitarpicr
My pass. side rattles terrible - Found where one of the plastic hold on clips on bottom by speaker was broken off. Gonna put a screw in it one of these days. Its worse when its cold.
Old Feb 26, 2009 | 07:38 PM
Bergerson's Avatar
Bergerson
while the door panel is off push, pull, pry, hit and try to figure out where the raddle is coming from...
Old Feb 26, 2009 | 07:41 PM
mxdadof2's Avatar
mxdadof2
for a minute , Jim mine does this every now and then . What could that be ?? sorry for the Hijack
Old Feb 26, 2009 | 07:44 PM
indyF-350psd
its the weather stripping all collapsed in and worn out. do the door seal mod and the chatter will disappear. about 20 bucks and an hour of your time...
Old Feb 26, 2009 | 07:46 PM
megawatt00's Avatar
megawatt00
I have looked at mine and it seems that the rubbergaskets are flattened out. I am going to fish a peice of rubber tubing through them in the spring. I'm going to use surgical type tubeing. it seems that the rear doors are worse. My truck is a super cab not a crew cab.
Old Feb 26, 2009 | 08:06 PM
mxdadof2's Avatar
mxdadof2
Mine is a supercab as well Jim sounds like we have the same problem, let me know what u find out and how it turns out........
Old Feb 26, 2009 | 09:08 PM
Powerstroke-7.3
Door Rattling
I checked everything that was suggested. My weather stripping is in suprisingly good shape. The door cannot be pushed in any more when shut. I checked all clips and screws when i had the door panel off...The door seems to stick out a tiny tiny bit towards the bottom of the door. other than that the door looks like all the other doors.
Old Feb 27, 2009 | 09:43 AM
Khart's Avatar
Khart
what size tubbing and what kind are you all putting in there?
Old Feb 27, 2009 | 04:35 PM
Powerstroke-7.3
Door Rattling
I havent put any in. The original weather stripping is still good
