Dealer installed AC
Old Mar 10, 2022 | 03:58 PM
  #91
Jadesupercab's Avatar
Jadesupercab
Originally Posted by lostinfords
What doesn't work?? the fan, the switch??? what component?
I have the same set up in my 79 super cab and the speed control switch is fifnicky, sometimes it doesn't supply pwr. to the blower fan, have to give it a nudge and it works, I have ben meaninhg to repair it for some time now...we all know how that goes. I get some parts from a guy in Jersey...dash auto air, he is real helpful, but I do believe they are manufactured aftermarket also, nostalgic or vintage air??
what is the fan powered by. Where does the power wire from the ac control switch go to. I had pack rats than dismantled the wiring. Luckily on a 77 I dont have too many wires
Old Mar 13, 2022 | 01:07 AM
  #92
Jadesupercab
Originally Posted by shabazz18
My 1978 has the ecomomy system. Compressor kicks on and everything seems to be in order except for a hole in the low pressure line so no freon. Are dryers/expansion valves available still? Basically your regular service parts. Also it appears the lines are just hose clamped instead of crimped. Does this mean I can get away with just replacing the hoses and flush everything/vaccum/recharge? (assuming the compressor works. Its definitely not locked up though)
can you see where the power wire coming out of the back the ac control *****? Mine was chewed off and I cant locate what it was getting power from. It would be the red capped female square blade connector that runs along with the 3 blade connector harness that runs to the blower motor.
Old Mar 23, 2022 | 10:21 PM
  #93
Csdrag's Avatar
Csdrag
Dealer installed AC
1973/79: There are TWO different Ford dealer installed A/C's.
Dealer Installed Economy A/C: Two control ***** in the center panel with two registers above.
The original glove box is intact.
Dealer Installed Deluxe A/C: The A/C plastic bezel sweeps across the dash, from the ash tray to the end, covering up the original glove box.
A hang-on (under the dash) glove box was furnished with the A/C installation kit.
The two ***** that operate the switches are on the left side of this bezel, which may be wood grained.
There is a Ford blue oval emblem on this bezel at the center right.
The two switches however, are the same for both A/C units.
D1RY19986A .. A/C Blower Switch-Use with Dealer Installed A/C (Motorcraft YH210) / Obsolete
KINSEL L/M in Beaumont TX has EIGHT: 800-816-2894.
WESLEY OBSOLETE PARTS in Liberty KY has FOUR: 606-787-5293.
GREEN SALES CO. in Cincinnati OH has FOUR: 800-543-4959.
BOB ALLEN FORD in Overland Park KS has FIVE: 800-676-0675.
DENNIS CARPENTER OBSOLETE PARTS in Concord NC has 13: 704-786-8139.
There are at least 100 more scattered around the US at other dealers, obsolete parts vendors.
E1FZ19618A .. A/C Evaporator Temperature Control Thermostat Switch-Use with Dealer Installed A/C (Motorcraft YH239) / Obsolete
GREEN SALES CO. has EIGHT.
LARRY ALLEN MOTOR CO. in Parsons KS has ONE: 620-421-0100.
TEAM FORD L/M in Silver City NM has ONE.
BYFORD L/M in Lawton OK has ONE.
HERMAN MOTOR CO. in Luverne MN has ONE.
LANDMARK MOTOR CO. in Tigard OR has ONE.
Sorry, no phone #'s listed for these last 4 Ford dealers.
Numbersdummy. I know this is a very old post so I am hoping it find
s you. I was unable to send you a private message through the forum. You have the best knowledge of these AC systems I have come across. How do you find out who has these old parts. I am in need of parts for my 78. I believe my AC was. Deluxe system. My control is just like the One in the Red dash in this post. This is the only place I have found a picture of a control like mine. Hoping you can help.
orich
18
Dec 28, 2023 10:46 PM
Sam's1967
284
Mar 31, 2017 12:43 PM
Hwklein88
Feb 19, 2017 05:08 PM
gbakman
22
Oct 11, 2016 05:39 PM
Croskey2010
Jun 22, 2016 06:56 PM
