transfer case problems??
Old Feb 22, 2009 | 01:12 PM
beaver steve's Avatar
beaver steve
My '87 6.9l lost 4H a couple of years ago and we've managed without it. But, yesterday there was a big clunk(while in 2WD) and the rig would not move itself. We had to put it in 4L to get it home.Wondering if that sounds like a broke transfer case to you all or what. Forward and reverse gears work fine on the main tranny. If it is the transfer case how expensive does this sound and would it be worth it to just get a replacement from the wrecker.
Old Feb 22, 2009 | 01:37 PM
Lazy K's Avatar
Lazy K
Before looking at the transfer case I would look for a broken rear axle shaft or even rear diff.
Old Feb 22, 2009 | 03:05 PM
kenpobuck's Avatar
kenpobuck
Better hope for the t-case. The local yard here wants $150 for a t-case but about $450 for a rear end and you have to pull it yourself.
Old Feb 22, 2009 | 09:37 PM
beaver steve
As I said it drives fine in 4L even with the front hubs disengaged. I assumed the rear diff was doing the driving.
Old Feb 22, 2009 | 09:50 PM
joe f350's Avatar
joe f350
i cant be tcase is a chain driven model
Old Feb 23, 2009 | 01:47 AM
RCrawler's Avatar
RCrawler
If if drives in 4L with the hubs unlocked, you need a transfer case. Sounds like the high range section is the problem.
Jason
Old Feb 23, 2009 | 09:31 PM
ford trans tech's Avatar
ford trans tech
you most likely have a bad shift fork in the transfer case
this transfer case is simple in design
get a shop manual remove the rear case half and check the 2 high 4 high fork it is the one closest to the rear and easy to replace much cheaper than a salvage unit
but like i said get a repair manual first
RubberDuck
Mar 9, 2010 11:19 AM
DBKER31
1997 - 2003 F150
Sep 3, 2009 10:51 AM
topfisherman
Mar 26, 2004 03:45 PM
Faithful Old Road Dog
Jun 6, 2003 04:07 PM
