5 speed year compatability
Old Mar 6, 2010 | 10:15 PM
RubberDuck's Avatar
RubberDuck
Okay, some of you know I smashed a tranny this weekend. Well, I have 2 spare trannys, but they are 2x4. I was thinking about buying another tranny and transfer case setup, just for the spare case.
I've seen a couple tranny and transfer case combos for around $500. But they are out of an 89 and 93. Both had the 7.3l diesel in front of them.
Are those the same tranny and transfer cases we have in our trucks? All the rebuild kits say they are up to 95.
Any input would be greatly appreciated guys.
Old Mar 7, 2010 | 06:58 AM
etldak's Avatar
etldak
according to my crash guide they will bolt up.but some of them have different gear ratio.
Old Mar 8, 2010 | 05:17 PM
coreylasalle's Avatar
coreylasalle
https://www.ford-trucks.com/forums/8...96-deisel.html
i think the 9th post by diesel dirk should help
Old Mar 8, 2010 | 05:46 PM
strokin'_tatsch's Avatar
strokin'_tatsch
that was some good info there reps on the way for the link. Cody, i'm texting Dustin right now to see if that other ZF5 he has is 2wd or 4wd. i will text you if it's a 4wd trans.
Old Mar 9, 2010 | 11:19 AM
Brown Falcon's Avatar
Brown Falcon
I was planning a swap to put the ZF5 into mine. I have a '88 with a 7.3 and it will bolt up to any 7.3, just need the clutch and flywheel from the year you are swapping in to.
kregalmach1
Dec 27, 2011 01:35 PM
seafire
Dec 1, 2010 07:11 PM
73BlackBeauty
Jan 12, 2009 04:57 PM
mycam8u2
Dec 13, 2007 08:24 AM
ANTIDodge
1983 - 2012 Ranger & B-Series
Nov 6, 2007 09:37 PM
