O/D light flashing
Old Feb 21, 2009 | 01:13 PM
djmicko's Avatar
djmicko
O/D light flashing
Hello i would like to try and get some help here if i can. I have a 2000 f350 diesel and im geting the O/D light flashing. I have tryed everything from the VSS, OSS and the TSS. I have had it at two shops and will be bring it to one more on monday. One shop told me i need a new trans and i said no way it drives way to good to need a trans. I picked it up from them and was going to do the trans my self to save me some money but it drives to good to think its that. I droped it off some wheres else and they did a lot of tests and said the same thing, it drives to good to need a new trans. Well that shop is now sending it out monday to a trans shop to see what they say. I have done the OSS TSS VSS, alternator, Battery cables corroded have been cleaned. Any help would be great??
Thanks
Danny
Old Feb 21, 2009 | 01:17 PM
megawatt00's Avatar
megawatt00
Welcome to FTE Danny. If the light is flashing then there should be a code stored. Can you get it scanned to see what codes are stored?
Old Feb 21, 2009 | 01:20 PM
djmicko's Avatar
djmicko
sorry about that i have a SCT X3 Power Flash and i pulled P0717,P0715 im going to go clear the codes and drive it and see what new ones i get.
Old Feb 21, 2009 | 01:35 PM
megawatt00's Avatar
megawatt00
P0715 Input/Turbine Speed Sensor Circuit Error
P0717 Input/Turbine Speed Sensor Circuit No Signal
No problem. Try to clear them and see iwhat happens.
djmicko's Avatar
djmicko
Just took it for a drive and all im geting is P0717 and P0715
Old Feb 21, 2009 | 01:44 PM
megawatt00's Avatar
megawatt00
I just did some looking around and there is a turbine speed sensor on the transmission. It is simular to the VSS on the rear dfferential. Take a look there and see if the wires are ok. Pull it out and clean it. I'll do a little more research for you.
Old Feb 21, 2009 | 01:48 PM
djmicko's Avatar
djmicko
The OSS and TSS are new from the dealer i just put the VSS in today from carquest
Old Feb 21, 2009 | 01:58 PM
megawatt00's Avatar
megawatt00
Ok you did the one that is on top of the transmission? That is all I could come up with.
Old Feb 21, 2009 | 07:47 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The turbine speed sensor is near the front of the trans, on top. If you replaced the sensor and you still get the codes then the problem is probably a bad wire to the sensor. The PCM doesn't tell you the sensor is bad, it says that it doesn't get a signal and that there is an electrical problem with that circuit. It's the wiring.
Robv27
Modular V10 (6.8l)
48
Nov 5, 2017 08:26 PM
Robv27
Aug 24, 2015 09:05 AM
Goober1979
Jan 15, 2014 01:32 PM
skoveng
Oct 23, 2008 02:08 PM
