Bad MPG
Old Feb 20, 2009 | 11:49 PM
jbarry328's Avatar
jbarry328
Bad MPG
I have a 2001 ranger 4x4 with the 3.0 in it. I just got the truck and it is spotless with only 33,000 miles on it. It seems to be getting bad miles per gallon i.e 10 to 12 on e-way........ If anyone has any idea or suggestions to help me improve it i would appreciate it....................thanks....
Old Feb 21, 2009 | 09:20 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
We'll need more vehicle info to make a good guess
Have the computer scanned for trouble codes & post ALL the code numbers & the sequence in which they were found, as any found can offer up good trouble shooting clues.
Most autoparts stores will do this at no cost, if the CEL is lit, some will do it even if you don't have a trouble light lit, so call around & ask.
Is this a flex fuel 3.0L & if so, are you using E-85?????
Certainly the weather, your driving habits, fuel used & if the vehicle has been messed with, like the air intake system, air filter type, like a oiled cotton gauze or foam type air filter, that can dirty up the MAF sensor, or a clogged air filter, or if someone has messed with the computer with a tuner, or installed a performance chip, or installed oversized tires & didn't reprogram the computer for it, or dirty sticking, leaking fuel injectors, or too much fuel pressure, clogged cat converter/s are some thoughts that come to mind that'll mess with mpg.
So we'll need some more inputs to make a better guess.
hivoltj
Apr 13, 2012 12:37 PM
almford1992
Dec 17, 2010 01:59 PM
FORD E-150
Aug 21, 2010 04:24 PM
94E1504.9L
Apr 28, 2010 09:21 AM
5smokey5
1978 - 1996 Big Bronco
Mar 24, 2008 05:33 PM
