1978 - 1996 Big Bronco
e4od trans problems
Old Mar 19, 2008 | 08:58 PM
5smokey5's Avatar
5smokey5
Cool e4od trans problems
hello everyone heres my scenario!!! i just got my trans rebuilt 120 miles ago. its an e4od,when i got it back she was shiftin flawlessly thenit got hung up in first gear and didnt shift till it hit 3000 rpm and went straight to 3rd.took it back to the shop that built the trans and he said the solenoid pack must be bad, so he replaced them and everything was fine for 130 miles now its doin the same f@!@#^* thing please help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 20, 2008 | 10:30 AM
Kemicalburns's Avatar
Kemicalburns
TAKE IT BACK, they should fix it
Old Mar 20, 2008 | 11:29 AM
5smokey5's Avatar
5smokey5
its at their garage now just lookin for some insight as to what it might be .........i cant see 2 selonoid packs being bad
Old Mar 20, 2008 | 12:09 PM
Mtthwvn73's Avatar
Mtthwvn73
Heck alot of these electronics are defective when you buy them. I've had to do the same thing with some starter selenoids. I'm glad i knew the guy, or I'd have to have bought about 3 of them. You just can't rely on all the electronics you buy today. Hopefully it's just another selenoid pack. Good luck.
Old Mar 21, 2008 | 05:23 PM
BroncoHector's Avatar
BroncoHector
Its either that the parts are bad or you have a bad ground or Something is causing the selinoid pack to go bad!
Old Mar 21, 2008 | 11:14 PM
rudedogii's Avatar
rudedogii
I read some stuff from a gear and transmission web site that shops were having trouble with a certain after market solenoid valve packs.
Try to find this info at: www.atra-gears.com
Hope this helps!
Old Mar 21, 2008 | 11:18 PM
rudedogii's Avatar
rudedogii
Sorry! Try www.atra.com
Old Mar 21, 2008 | 11:53 PM
rudedogii's Avatar
rudedogii
One more time. http://www.gearsmagazine.com/
I found the info in the Sept 2001 gears Magazine on the atra web site. Lucky I found a printed copy in all my stuff!
Old Mar 24, 2008 | 05:33 PM
5smokey5's Avatar
5smokey5
thanks for the info. just got the truck back and put 50 miles on it so far so good!!!!!!! the mechanic said the wirin harness was corroded and he replaced it,im keepin my fingers crossed.ill let you know how it pans out
LAbronc
Jan 1, 2015 09:29 PM
zottyzot
Nov 15, 2012 12:40 PM
82MustangGT
Feb 23, 2009 05:51 PM
kaufmanlawn
Mar 16, 2006 04:49 AM
scmac53
Apr 21, 2005 06:40 AM
