E4OD output shaft swap
Old Apr 12, 2012 | 04:11 PM
hivoltj's Avatar
hivoltj
How bad is it? I have a '92 F-150 5.0 E4OD truck. 2wd. The front pump in the trans whines, and the pressure is low. There is a 60k mile after-rebuild 4WD E4OD on craigslist. How bad is it to swap the output shaft? I'd assume I'll have to pull the pump, gear sets, etc. I have rebuilt some non overdrive automatics before.
Old Apr 12, 2012 | 04:52 PM
subford's Avatar
subford
It is about the last part you take out of it.
Old Apr 12, 2012 | 07:26 PM
rla2005's Avatar
rla2005
X2 on Bill's statement above. It is not an easy job and full of pitfalls.
Old Apr 13, 2012 | 12:37 PM
hivoltj's Avatar
hivoltj
Well crap. If the trans has all the proper upgrades it may be worth it if I can get it cheap enough. RNR-ing parts I think I can handle myself, it's all the machining and upgrades that I can't.
IIRC I'll be about 1600-1700 into a proper rebuild of the '92 E4OD. So many parts need replaced, the pump, support bearing, solenoids etc. to do a proper rebuild. The guy with the rebuilt 4x4 E4OD is asking $800. I was thinking of more like $500-$600 or it won't be worth the hassle.
I'm going to contact the original owner who had the trans rebuilt and see what all was done to it.
qdeezie
Dec 15, 2014 08:48 AM
joshuahaney
Dec 9, 2012 09:22 AM
Thomas A
May 24, 2006 10:48 PM
edderd
Apr 23, 2005 12:28 AM
mudog715
Apr 10, 2005 09:36 PM
