460 problem
Old Feb 22, 2009 | 05:55 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I've had mine up over 100, not that I would recommend it.....
the tach redlines @ 5800.
Old Feb 22, 2009 | 06:56 PM
Bdox's Avatar
Bdox
That 460 should have it's compression checked.
Pushrods don't get bent arbitrarily.
Old Feb 24, 2009 | 10:03 AM
j74250's Avatar
j74250
Update,
Pulled both heads, cylinder with bent pushrod also had bent valve. all cylinders had coolant in them, luckily the rings were still good and no coolant in the oil. a handfull of the valve were a light sand yellow color. we took the heads to a local Ford motor guy(49 years of fords) Garrett Machine if anybody cares. said he is going to replace all the exhaust valves and regrind the intake valves. He said to definatly pull all th emission stuff, i am gonna guess by the posts that its a matter of preference and he said to put on a bigger carb or rejet the one on it. will post more later. thank you for the help again
Old Feb 24, 2009 | 10:47 AM
Bdox's Avatar
Bdox
Did your motor man (who doesn't understand emission controls,) determine the cause of the bent valve?
While it's apart, check the timing chain
Old Feb 24, 2009 | 10:51 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Make sure he magnafluxes the heads before bothering to work on them.
When I pulled my engine last spring I sent the heads to the machine shop (just for fun)and found hairline cracks on almost every cylinder.
If you're going to dispense with the emissions why not grind the thermactor humps out of the exhaust ports while you have the chance?
I think you'll see a bigger gain there than by removing the emissions stuff.
Edit: OF COURSE, replace the timing chain with a non-retarded one. Maybe even the cam etc.. given that you (he) bent a valve and pushrod and aren't concerned with emissions.
Old Feb 24, 2009 | 01:48 PM
j74250's Avatar
j74250
He understands emissions, but doesnt care for them, hes a racer. Again this isnt my engine or my $$$$ so i cant say what exactly is going to be done, I do know Garretts rep, and he will only do it the right way, no half way stuff.
7.3 down
Dec 16, 2013 11:24 AM
TheLockNLoad
Apr 18, 2011 08:29 PM
TheMech
Dec 1, 2009 03:03 AM
tommygun53
1983 - 2012 Ranger & B-Series
Jul 18, 2008 04:02 PM
John Rowe
21
Feb 10, 2006 10:56 PM
