Help transmission gods!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hello
I have posted a few times but got no answers. So i figured if I put a eye catcher maybe i will get some responses. I have a ford ranger 98 4x4 auto 3.0 liter with the 4r443 transmission. Fluid level good , not burnt. all forward gears are working great, smooth etc. Reverse is 99% not there . If i push the truck and hit the gas it will roll a little bit . Need some help
Your 4R55E trans probably needs a new reverse clutch. It might be a failed seal in the clutch, but that doesn't really matter. It's a rebuild either way.
