Transmission filter
Old Apr 17, 2013 | 11:47 AM
ayre's Avatar
ayre
Transmission filter
I am hoping to get some help on changing a transmission filter on my 1997 Ford Expedition. It is slipping out of drive after using 4x4 to get out of snow. I can start in second gear, then shift to drive and drives fine till i come to a stop, then have to start in second again. I wanted to try changing the filter and transmission fluid before giving up completly on the transmission. Thank you, Ayre.
Old Apr 17, 2013 | 04:19 PM
alloro's Avatar
alloro
By "get some help" do you mean you need advice or that you're looking for someone in your area to come by and help you?
Old Apr 17, 2013 | 07:08 PM
ayre's Avatar
ayre
I was looking for advice, another member said the it needed a new transmission. My father had, had the same problem once and by changing the filter and tranny fluid, he never had another problem. I had the tranny rebuilt about 25,000 miles ago. It had gotten water in it from sitting in a lake overnight. (another story). Could you please tell me your opinion, I would appreciatte it, thank you, Ayre.
Old Apr 18, 2013 | 02:02 AM
alloro's Avatar
alloro
First it spent time under water, and now you again have a problem after being buried in the snow. If it were me I would first replace the DTRS on the side of the tranny. If moisture got into this sensor, the tranny could be confused as to where the shift lever actually is.
Old Apr 18, 2013 | 01:59 PM
ayre's Avatar
ayre
Ok, thank you Alloro.
50th ann
1997 - 2003 F150
Mar 21, 2009 11:37 AM
baddmove
Bronco II
22
Jan 15, 2009 11:51 AM
Densue
Feb 29, 2008 11:23 AM
Bigemus56
1997 - 2003 F150
Sep 6, 2004 10:13 AM
Mscales
May 10, 2003 08:01 PM
