Sponsored by: Real Truck
washer fluid light?
Old Feb 19, 2009 | 04:30 PM
zed326's Avatar
zed326
Question washer fluid light?
Does anyone know if the o5 sd has a light for low washer fluid? i can see plugs in the tank but when i run out there is no light on? or did ford just cheap out some more?
Old Feb 19, 2009 | 10:31 PM
DAVE67FD's Avatar
DAVE67FD
The connectors probably for the pump. The easiest way to tell, check your owners manual. If you don't have one, run it till it's dry. If a light comes on, bingo. If not you either don't have one or it's burnt out. I don't believe my 06 has one.
Old Feb 19, 2009 | 10:35 PM
Furian's Avatar
Furian
You Keep What You Kill
I have a 2005 F350 4x4 XL and there is no low washer fluid light. Maybe there is one on the XLT and Lariat models.
Old Feb 19, 2009 | 11:03 PM
powerstroke72's Avatar
powerstroke72
I've never seen it on my '05 and in checking the manual, it appears to check just about everything but that.
Old Feb 20, 2009 | 03:50 AM
zed326's Avatar
zed326
so it is ford just cheaping out again!!!
Old Feb 20, 2009 | 07:07 AM
firemanpat29's Avatar
firemanpat29
Wow some people just have to complain. Put a gallon in it and go on with your day. If it had a light you would be on here complaining that it came on and you still had enough fluid for 2 wash cycles, then somebody would say they get three cycles and you would want to warranty a whole new bottle. No there is no light. There is also no light that tells you the window is down, or that the tailgate is unlocked, its a truck not a 747 how many lights do we really need?
Old Feb 20, 2009 | 08:46 AM
Downriver Thunder's Avatar
Downriver Thunder
I know I had one on my 00 Excursion Limited but not sure on my 05 250. Never usually let it run that low beings I drive the freeway alot.
Old Feb 20, 2009 | 09:02 AM
rollerstud98's Avatar
rollerstud98
My 99 Ram had it, it is nice to have, once the light came on I'd always pick up a new jug, then run it dry and filler up, never ran out in an inconvenient place with no fluid in the truck to refill with.
Old Feb 20, 2009 | 04:10 PM
zed326's Avatar
zed326
wow firemanpat29 sounds like you have more complaints then my one question..........so who has the problem??????
Old Feb 20, 2009 | 05:39 PM
UGA33's Avatar
UGA33
There isnt a low washer fluid lights on these trucks to my knowledge. Just fill it up and be done with it. I wouldnt call out Ford for cheaping out by not installing a low washer fluid indicator. They just focused their attention on more important things like the best payload and towing capacities in the class.
Ex03AK
Oct 12, 2022 04:25 PM
rpbf350
Mar 9, 2014 04:06 PM
Big Greenie
Nov 11, 2009 05:32 PM
oahuobx
Sep 25, 2006 06:42 PM
nickalbu
Mar 14, 2005 10:34 AM
