MAF or not???
Old Mar 28, 2001 | 10:00 AM
noremac19's Avatar
noremac19
MAF or not???
I have a 1994 F-150, 5.0l, im wondering if it is mass air flow or speed density? Is there a easy way to tell? I have 2 hoses going from the filter box to the throttle body.
Old Mar 28, 2001 | 03:48 PM
Eddie's Avatar
Eddie
MAF or not???
"Two hoses"--that's the giveaway. You have a speed density setup.
Were it MAF it would have the same twin-butterly throttle body, a plastic "Y" adaptor to join both bores into one large-diameter hose leading across to the air box.
You would also have a '95Calif./'96 50-state truck, and OBD-II.
Eddie
Old Mar 28, 2001 | 04:09 PM
markus's Avatar
markus
MAF or not???
I believe in the 92-96 Trucks work this way:
Automatic Transmission Trucks had MAF
Manual Transmission Trucks had Speed Density
Except all the California Trucks got MAF too.
Old Mar 28, 2001 | 06:13 PM
Pastmaster's Avatar
Pastmaster
MAF or not???
That's sorta true except Mass air didn't come out til 1994. And I don't think 351's got it until 1995. 300's didn't get Mass air until 1996. (49states) And possibly the 460 never got it. I don't know why not, they used a 302 computer and firing order anyway.
Old Mar 29, 2001 | 01:16 AM
hotrodford_88's Avatar
hotrodford_88
MAF or not???
Actually some of the earlier trucks (california) had mass air before 94. I found a note in my Chiltons repair manual that stated that.
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Old Mar 29, 2001 | 04:10 PM
Eddie's Avatar
Eddie
MAF or not???
Gentlemen, I stand corrected!
Burning question: was there an OBD-I MAF system available for 4.9L, manual transmission trucks? What was it available on? Which model(s) do I need to be searching the boneyards for? Over 8,500-lb. GVW trucks and vans?
Eddie
Old Mar 29, 2001 | 05:36 PM
tom87's Avatar
tom87
MAF or not???
Eddie,
Have you looked into trying to find somebody to burn a chip? That seems like the easy way out if it is possible.
Just my 2 cents.
Tom
Rockwall, TX
87 F150 4.9 4spd
Bone Stock
Old Mar 29, 2001 | 07:25 PM
Pastmaster's Avatar
Pastmaster
MAF or not???
Hotrodford_88: That is a possibility, but none inside the other 49 states had em.
Old Mar 29, 2001 | 07:48 PM
hotrodford_88
MAF or not???
Right, California is the first to get everything. Darn the luck.
Can see both below.
Old Mar 30, 2001 | 07:55 AM
Pastmaster's Avatar
Pastmaster
MAF or not???
I do believe I can live without their 4 catalytic convertor's though. Talk about a power choker.
Old Mar 30, 2001 | 02:09 PM
hotrodford_88
MAF or not???
I have seen that some of the newer cars (crown vics, caprices, and the like) are coming with (get this) 6 Cats! I cannot believe that, it's no wonder why car prices are so stinking high!
Can see both below.
Old Mar 30, 2001 | 02:24 PM
noremac19's Avatar
noremac19
MAF or not???
Whats the big difference between mass airflow and speed density?
Old Mar 30, 2001 | 02:30 PM
hotrodford_88
MAF or not???
Mass air, measures the amount of air coming into the engine, and figures the ari/fuel ratio by that.
Speed density, takes a measurement of the speed you are going and figures the air fuel ratio.
Therefore mass air is better, it allows for Modifications to be done to the engine that affect air flow. With speed density, if you change the amount of air going in, then you mess up the calculation of the air fuel ratio by the computer.
Can see both below.
Old Mar 30, 2001 | 08:56 PM
Pastmaster's Avatar
Pastmaster
MAF or not???
Today's cat convertors are more breathable than our years. I guess this would explain why most cars have 4 anymore. My best friend has a 96 Gt 4.6L and his has 4. I can't imagine how it will run with a X-pipe and 2 convertors.
Old Mar 31, 2001 | 03:00 PM
noremac19's Avatar
noremac19
MAF or not???
ok its me again, I have put true duel exhaust and a K&N air cone on my truck, its speed density, could that be the reason why it backfires when i down shift?? Is there anyway to cure it?? How hard is it to change it over to a mass air flow system?
