heater core
Old Feb 20, 2009 | 07:54 AM
adams.construction's Avatar
adams.construction
heater core
I haven't even had a chance to look at it yet, but i was wondering how hard it is to put a heater core in a 87 f250. thanks
Old Feb 20, 2009 | 08:44 AM
xltlariat87's Avatar
xltlariat87
with the engine cool, drain anti-freeze, disconnect heater hoses from heater core, on the inside of the cab remove the glove box, remove the seven screws that hold the cover to the heater box, remove the heater core, hope this helps.
Old Feb 20, 2009 | 08:48 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Very simple.
It is behind the glove box.
I can likely do one in under ten minutes.
Old Feb 20, 2009 | 08:58 AM
tjc transport's Avatar
tjc transport
i ain't rite
yup. very easy 10 minute job. and you don't even have to drain the radiator, because the core is higher than the radiator. just take the hoses off, and stick the ends into the hood hinge.
Old Feb 20, 2009 | 11:05 AM
quicklook2's Avatar
quicklook2
if you have carpeting put a towel/plastic down.
mark hoses before unhooking them.
Old Feb 20, 2009 | 12:53 PM
adams.construction
Thanks helps a lot
