Electrical nightmare
Old Feb 18, 2009 | 01:57 PM
superduty4x4's Avatar
superduty4x4
No smoke is not good to hear... that clicking is likely the IDM trying to fire but it can't for some reason. Checked fuses?
Old Feb 18, 2009 | 02:07 PM
billfishnut's Avatar
billfishnut
Cool, thanks a bunch guys. BTW I was able to get enough charge to make smoke and not quite fire. Gotta make a few calls for batteries.
General question: How much life do you guys usually get from a set of batts? These are only 19 months old.
Old Feb 18, 2009 | 02:09 PM
Kwikkordead's Avatar
Kwikkordead
Subscribing.
I don't have any ideas other than it sounds like a relay is switching on and off for some reason.
The one second interval is what gives that away.
If it were a dead battery causing it, it would be more like a machine gun T-T-T-T-T-T-T-T.
Old Feb 18, 2009 | 02:20 PM
billfishnut
Kwik, not surprise to hear you ring in on this one. Oddly, I pulled my cab light relay because it was doing the same thing at about the same interval. I figured to put it back in after the problem is solved. I am calling to see if my batts are under warrenty if they are, I will try to get them changed out.
Old Feb 18, 2009 | 02:42 PM
billfishnut
Wheee Hheeew!!!!!
Truck just fired up!!! Letting it idle while I call around for batts.
Thanks for the help gents.
Old Feb 18, 2009 | 07:14 PM
billfishnut
New update:
Took truck to Advance Auto (warrenty on batts). With batts disconnected, both tested good and load testing of charging and starting system all checked out OK.
Until next time?????
Old Feb 18, 2009 | 11:40 PM
7.3johnsonville's Avatar
7.3johnsonville
hope it works for ya. anyones thought on a GEM?
blrman1962
Jan 24, 2012 02:00 PM
hink10
44
Mar 12, 2011 11:48 AM
Bertelrud
Jun 2, 2009 07:41 AM
Bossman7121
24
Feb 16, 2007 07:57 AM
79man
Nov 29, 2006 01:07 PM
