thermostat issues
Old Feb 16, 2009 | 01:23 PM
highboy87's Avatar
highboy87
thermostat issues
so my thermostat went out... and it has been hell to get it fixed. it has been too cold here to get RTV sealant to cure, can i put the gasket in dry? i broke the housing so as soon as i pull a new one, i need to know what i can do to get this thing fixed. i'm tired of messing with it.. i have a guy coming to look at it to buy it and i need this problem solved. help?
Old Feb 17, 2009 | 05:14 AM
wild manimal's Avatar
wild manimal
Probably not the best idea to go dry with the gasket. Might not leak, but it would suck to put it on dry, fill up the radiator, start the truck,see that it leaks, take it all off again, lose more coolant, put the R.T.V. on, put the thermostat back on, reassemble it.......
I would think it will cure up eventually....
Old Feb 17, 2009 | 10:48 PM
bjafeman's Avatar
bjafeman
1) Find an extension cord and heat gun (or hair dryer).
2) Remove the housing and fire up the heat gun on the block. Set in place, close the hood, go make a sandwich.
3) Prep the housing with RTV, stat and gasket while you're inside, warm and making sandwiches. Make sure you don't mix ingredients between the two projects.
4) After the sandwich is gone and the housing has had some time to set with the RTV, put the final layer of RTV on the gasket (between the gasket and block) and head outside.
5) Remove heat gun and put housing in place. Torque to specs
6) Give the setup a few minutes to cure (residual block heat should buy you a few minutes).
7) Fire it up, get the truck to temp and check for leaks.
8) More sandwiches
9) Check for leaks one last time and drive for a bit.
Totally making this up, haven't tried this myself. Live in SoCal. Dead of winter is about 45 degrees, so I'd be lying if I said I tried this before.
Old Feb 18, 2009 | 12:30 AM
fmc400's Avatar
fmc400
MSEE
I buy the gaskets that have adhesive on one side, which holds the thermostat in the housing while you put it on. That way you only need RTV on the gasket-to-block surface. It doesn't take much though. I'm sorry, but there's no way you're going to get it to cure out in the cold weather. The RT in RTV stands for "room temperature." I don't recommend trying without sealer. Now, Edelbrock makes a kind of sealant called Gasgacinch that you can use on thermostat housing gaskets. It looks like rubber glue, instead of RTV. You might try looking that up and seeing what kind of temperature it needs to cure.
Old Feb 18, 2009 | 10:17 AM
highboy87's Avatar
highboy87
that's what i did. i took the housing inside and got everything ready, and let it set. and the next day took it out and hooked it all up. and then when i took it for a drive, it was a white out and i drove into a drift and the snow was so deep i couldn't open my door. thank god for neighbors with big tractors or my truck may have been there till the snow melted...
Old Feb 18, 2009 | 06:01 PM
murph77's Avatar
murph77
I just replaced mine a few weeks back. I hate scraping old gaskets and sealant off, so I don't use the sealant if I don't need to. It took a little time and patients, but I used a razor knife blade to hold the thermostat and gasket in place as I put the housing over them. I only had to cuss a few times, and everything worked out great. No leaks now, and no scraping next time. Give it a try.
Murph.
Old Feb 18, 2009 | 06:20 PM
slomafarms's Avatar
slomafarms
it will cure...ive been there done that in -5F weather
Old Feb 26, 2009 | 02:15 PM
welder79's Avatar
welder79
I've heard to just use grease?
Old Feb 27, 2009 | 09:47 AM
AbandonedBronco's Avatar
AbandonedBronco
I've put in a thermostat in a parking lot in 5 - 10 degree weather before with no sealant of any kind. Just the dry gasket. It didn't leak for over a year.
It's always better to use some, but it's doable without, especially in cold weather.
Old Mar 2, 2009 | 03:09 PM
Harfend's Avatar
Harfend
Permatec offers a "thermostat/waterpump" gasket sealant that works absolutely the first time. (for me at least) even if the block is wet, it's cold out, whatever! You can find it right next to the RTV at the hardware/parts store. The best part is no messy clean-up if you need to remove the part. It peels off clean.
Good Luck!
Old Mar 2, 2009 | 06:17 PM
Beechkid's Avatar
Beechkid
At slep boys they have aftermarket housings (chrome) that use an o-ring instead of a gasket- if that helps!
cworthington
1997 - 2003 F150
Feb 18, 2015 07:50 PM
snakedoc
Apr 23, 2011 11:20 PM
cmysho
43
Jan 22, 2011 12:54 AM
cargoflyr69
1983 - 2012 Ranger & B-Series
Dec 10, 2007 07:10 AM
DS02F250
Mar 2, 2003 02:09 PM
