If those 2 holes at the back are coolant passages then there's no need to block it off like allen said. If not, the 300's don't like havin a cold carb so you can make a plate to fit the bottom and run coolant to it. Or you can run a coolant plate between the carb and manifold.
Those two ports on the manifold are for vacuum devices like EGR, dizzy, brake booster if you need them or want to use them. You don't have to block off the indent on the bottom but it is a good idea to fab a plate from say 3/8 or 1/2 aluminum drilled and tapped for heater hose barbs and spliced in to a heater hose for manifold/carb heat and thus avoid carb icing and bogging. If using the stock exhaust manifold, it bolts right up for that just like on a stock intake and you don't need the water heat.
Thanks for all of the wonderful information guys! I'm really excited... Just got my tax returns and bought a hedman header, the intake and carb, accel super stock coil, and edelbrock dual inlet dual outlet 2.25" muffler, and recurve springs for the distributor
I will for sure. I picked up that intake manifold and it came with this motorcraft carb for $140 shipped and i'm not sure wether to use it or have my dad rebuild a quadrajet for me.
so would't the whole carb straddle both sides? IDK what carb to use can some of you give me some suggestions? I've been told by many that holley's suck when offroading and are on inclines... Any help would be appreciated
The Qjet would be fine...just need a spread bore/square bore adapter plate (TransDapt #2034 or Edelbrock #2696) and it should not be affected by fuel bowl slosh like the Holleys although baffles and jet extensions are available.
The carb in the picture is a 2700 VV...considered by many to be a #1, AAA, genuine POS.
Do some research on it.
QJet is a good carb. As long as you know how to set it up, it'll work great on your 300. 4BBL carb goes "sideways" on a 300, primaries towards the valve cover. +1 on manifold heat.
