05 Steamer
Old Feb 15, 2009 | 12:08 AM
iduger's Avatar
iduger
05 Steamer
Need help just bought 05 diesel. Started pumping steam from exhaust. Could it be the egr valve ,i know its using antifreeze. Any help would be great.
Old Feb 15, 2009 | 12:57 AM
bismic's Avatar
bismic
Could be several things, but it sounds like an EGR cooler. To verify, jack up the back end and pull the EGR valve. If it is wet with coolant, it is the EGR cooler. If the EGR cooler is bad, then the oil cooler should really be replaced as well. What does the smoke smell like?
Old Feb 15, 2009 | 07:31 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Hey Bismic, when do you sleep? I see the reply is almost 2 AM and back on here @ 8:30? You're one dedicated member!
Old Feb 15, 2009 | 07:38 AM
bismic's Avatar
bismic
Yeah - I have an old dog that needs to go out at night
Old Feb 15, 2009 | 09:23 AM
iduger's Avatar
iduger
Are these dealer only parts? Where is the egr cooler and the oil cooler. Is this something i can handle at home. As far as smell there really isnt any.
Old Feb 15, 2009 | 09:25 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
If you just bought it I'd take it back to where you got it and have them fix it. Are you under 100k? If so it will still be under warranty and only cost you the $100 deductible.
Old Feb 15, 2009 | 09:30 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Page 19: Cooling System Check in the Tech folder there's a link to stuff like this under the 6.0 Bible but here's the EGR cooler, also here's the oil cooler http://dan.prxy.org/Truck/6L_bible_h.../Page_018.html
Old Feb 15, 2009 | 09:40 AM
iduger's Avatar
iduger
Ya its just over the limit So this will be on my dime. Do ihave to replace the cooler and the valve, or does the valve get stuck and let coolant in.After the truck warms up the steamer stops steaming.
Old Feb 15, 2009 | 09:43 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
If it is the cooler now would be a good time to delete it. It is a problem with the 6.0's and you're better off without it. I am planning on deleting mine when I get some time and money.
Old Feb 15, 2009 | 09:52 AM
iduger's Avatar
iduger
Whats the fastest way to get back on the road. does the cooler break or get cloged. just curious what causes the cooler to fail an dwhat happens to it when it does fail.
Old Feb 15, 2009 | 10:24 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Not sure what a new EGR cooler costs but here's a link that might help you and at the end of the 2nd page there's a link to some EGR delete kits. I guess as far as getting it back on the road fast that would depend on your abilities, and possibly which route you go, as far as parts availibility and shipping. https://www.ford-trucks.com/forums/8...gr-delete.html Also like Bismic said it would be a good time to replace the oil cooler so you're not tearing it apart again in the possibly near future.
Old Feb 15, 2009 | 10:50 AM
ShinyRedTruck's Avatar
ShinyRedTruck
why does the oil cooler need replacing?
I am curious why it is recommended to replace oil cooler if egr cooler is leaking. What it the technical reasoning behind this? Doug
Old Feb 15, 2009 | 11:00 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
https://www.ford-trucks.com/forums/8...-problems.html Post #4 explains how the EGR cooler can go bad, I'm searching for a good post that would explain why to do the oil cooler at the same time, I remember reading about it but can't give a concrete reason off the top of my head. I'll get back to ya if I find something, I just remember reading that when one fails the other usually isn't far behind.
Old Feb 15, 2009 | 11:06 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
https://www.ford-trucks.com/forums/7...ow-bottle.html Post # 13 might persuade you, but read the whole thing. Post # 6 would be enough for me to do it. BTW not to sound like a jerk but the Search feature will give you what you're looking for, most of the time. Good luck!
Old Feb 15, 2009 | 11:20 AM
ShinyRedTruck
oil cooler
My understanding is that coolant passes thru the oil cooler first and then into the egr cooler. What I am not understanding is how a leak in the egr cooler would cause a failure in the oil cooler. Can anyone explain this or am I asking the wrong question?
