05 Steamer
Old Feb 15, 2009 | 11:52 AM
mhoefer's Avatar
mhoefer
If the EGR cooler is clogged with casting sand and failing, then chances are the same problem is happening with the oil cooler. Just that the EGR cooler gets much hotter with the exhaust gas temps which then causes solder/welds to come loose hence the leaks. So, once you are in there doing one cooler you might as well do both so you dont have to go another weekend without your truck....
Old Feb 15, 2009 | 01:04 PM
iduger's Avatar
iduger
i will ask again what is the quickest way to get back on the road. if i disconnect the egr valve will this allow me to drive safely untill i can break it down . help please
Old Feb 15, 2009 | 01:33 PM
bismic's Avatar
bismic
Do the check for EGR cooler leak by jacking the back end up and removing th EGR valve. If it is wet below the EGR valve, your EGR cooler has leaked. It is a fairly big job to replace it. Only you can decide whether it is in your skill set or not. I will look for instructions on replacing the EGR cooler. If it is the EGR cooler leaking, then driving the vehicle can result in hydrolocking your engine and doing major damage. Simply unplugging the EGR valve does not prevent further damage.
The oil cooler passages (coolant side) are small. They plug easily. When it plugs, it starves the EGR cooler from coolant flow and it fails due to excessive heat. Then you have coolant pouring into the intake and exhaust. You may not HAVE to replace the oil cooler, but it should be pulled and checked for pluggage at a minimum.
Old Feb 15, 2009 | 04:50 PM
iduger's Avatar
iduger
thanks for everyones help. I diconnected the egr and it stil is smoking. Can I find the cooler cheeper than at the dealer. Also should i just completly get rid of it. Thanks again.
Old Feb 15, 2009 | 04:53 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Old Feb 15, 2009 | 05:15 PM
Benchwrench's Avatar
Benchwrench
The emissions circuit should be a zero deductible when you take it to the dealer for repair and if it falls within 100,000 miles.
to the OP,
You need to remove the egr valve not just unplug it.
it is held by a couple of bolts, once you pull the valve out look inside the intake and see if it looks wet. First park the truck so the rear tires are significantly higher than the front tires. Gravity will move any liquid to your inspection hole which is the removed egr valve.
eriddell
Jun 25, 2011 08:24 AM
xmontex4
Jan 7, 2011 05:04 AM
wturkey
Jul 15, 2008 06:48 AM
vortech50
1997 - 2003 F150
Apr 30, 2006 12:39 PM
05-350
Car/truck Buying Advice
Aug 11, 2004 10:57 AM
