6637 intake
Old Feb 14, 2009 | 12:16 AM
iowastroker's Avatar
iowastroker
6637 intake
Any one with pic and list of what they used for this would be get. Im look at doing this to mine.
Old Feb 14, 2009 | 01:01 AM
c00nhunterjoe's Avatar
c00nhunterjoe
1- 6637 air filter.
1- 45 degree elbow
1- 4 inch constant tension clamp
thats all you need for the mod, what i have pictured is also the crankcase vent mod
Old Feb 14, 2009 | 09:41 AM
tjbeggs's Avatar
tjbeggs
Here is mine when it was in my 95
Pretty much the same parts as Joe. I just used a longer legged 45, and a different boot. All the parts I used are from Napa.
Old Feb 14, 2009 | 09:55 AM
helifixer's Avatar
helifixer
if you don't want to buy new hoses, and want the filter more square on the fender, take the black flexible hose off of the original filter housing (goes from filter box to aluminum pipe at valve cover) turn it around, cut it off to the first rib (the cut off piece will be tapered) , leaving the rib. then carefully cut the blocks from between the first and second rib, this will allow the factory clamp to fit down in the grove. set the filter in place and set the 45 degree pipe over it and the hose and mark it for cutting
Old Feb 14, 2009 | 10:21 AM
FARM69's Avatar
FARM69
I dont have a pic of the stock setup but, I used a 4" piece of pipe and made a 45 degree angle with it. It's not as pretty as the ones shown above, but it works great and cheap.
Old Feb 14, 2009 | 01:50 PM
iowastroker
one question how did you do the crankcase vent mod. I this mine is bad because when i get on it going up hills its white smoke that come out and black. I think i miss something there.
Old Feb 14, 2009 | 06:59 PM
c00nhunterjoe
thats probably not the crankcase doing that, probably have another issue, but this is the crankcase vent mod, i used 5/8's heater hose.
Old Feb 14, 2009 | 07:41 PM
F-350PSD's Avatar
F-350PSD
What does the crankcase mod do?
Old Feb 14, 2009 | 08:02 PM
KevinC.'s Avatar
KevinC.
Vents blow by into the atmosphere instead of your turbo.
Old Feb 14, 2009 | 08:44 PM
F-350PSD's Avatar
F-350PSD
Ok i feel ashamed to ask but what is the advantage to that?
-thanks
Old Feb 14, 2009 | 08:52 PM
blake 7.3L's Avatar
blake 7.3L
It makes the intake air cooler because you are not dumping the hot crankcase gas into the intake.
Old Feb 14, 2009 | 10:01 PM
FARM69's Avatar
FARM69
I would think that would minimal.... The main thing with CCV is the oil residue that it can promote IC boots to blow off during high boost conditions with a IC.
Old Feb 14, 2009 | 11:57 PM
iowastroker
ok it thats not the problem would you have a ideal on what it is?
Old Feb 15, 2009 | 10:05 AM
FARM69's Avatar
FARM69
You need to start small and work your way up when diagnosing. As always, check your filters and replace if necessary. It might be possible that your kitty is clogged up as well.
We need to know more information than its putting out white and black smoke going up a hill. What are the operating temps? Does it do it every time? Any modifications to the engine?
Old Feb 15, 2009 | 02:11 PM
iowastroker
the truck runs run the n and o for temp. and there is no mods to the truck. it doesnt do it all the but sometime i does. and it white smoke only thats is. the reason i think its the crank case breather is because when i see it happen i can really here the turbo spooling up
