Carb?
Old Feb 12, 2009 | 05:58 PM
fordxl68's Avatar
fordxl68
Carb?
I have a 1968 390,.30 over,RPM intake,cam is 224 int-234 exh,540 int lift,560 exh lift and 110 duration, headers,MSD full ignition,C6 trans,373 posi rear. I have a holley street avenger 660 on it now. I dont like the carb. I am going to buy a holley 750 not sure what one yet. which is better for me mech secondaries or vacuum? I run about 3000 rpms at 64 mph. car weighs about 3300lbs. any help would be appreciated
Old Feb 12, 2009 | 06:25 PM
Bear 45/70's Avatar
Bear 45/70
In a truck, unless it is a real race truck, mechanical secondaries are a no-no and a low end performance killer, do to over carburation issues. In a really light car with a less than 3.50 rear end you might get away with a double pumper but, they really only belong an a race engine which is what they we developed for. Why do you think you need a bigger carb? How high are you revving this engine? A 660 carb is good to about 5750 rpm. A 750 will take you to 6500 rpm, that is if your cam is up to it along with your exhaust system. Too much carb is the worst mistake most people make. To much carb hurts low end throttle response and gas mileage.
Old Feb 12, 2009 | 07:17 PM
fordxl68's Avatar
fordxl68
carb
The carb seems to bog a little off the line. it dosnt have instant throttle response. and I cant tell when the secondaries kick in. I was told the street avenger wasnt that good of a carb. looking for a change
Old Feb 12, 2009 | 08:06 PM
Bear 45/70's Avatar
Bear 45/70
A bigger carb will only make it worse and a double pumper will make it even worse than a bigger carb. You need to go through and set up your carb propurely. If you don't have the instruction sheets for your carb then check the Holley site "Tech Section" and find your carb instructions there.
Old Feb 12, 2009 | 09:34 PM
fordxl68's Avatar
fordxl68
carb
thanks for the help
Old Feb 13, 2009 | 08:33 AM
HOTWRENCH's Avatar
HOTWRENCH
Engine Setup
Bears right you can't just bolt a carb on an engine combo and expect it to be OK. Many factors influence the setup that you will eventually come up with. Different pump cams , different squirters , jets, secondary springs, and then there is the distributor setup , getting the advance curve optimized for your combo is just as important and can sometimes mimic carb problems if not setup correctly.
Just some things that come to mind ----- Hotwrench
Old Mar 8, 2009 | 05:41 PM
eriksf250's Avatar
eriksf250
what cam are you running? I run a 750 Edelbrock on my 390 in a 67 galaxie with a C6 and 3.00 gears and she does just fine with the stock cam. another thing to look at is what size jets you are running. you may have the wrong jet size in it and it may be running too rich for that carb and cause your bogging.
Old Mar 13, 2009 | 03:27 PM
OrangeJuice's Avatar
OrangeJuice
I have a 390 bored .60 over and running an Edelbrock 750cfm (1411 model) with a decent cam. I had the distributor recurved and when I took it in to get it all dialed in, fuel and air, they enlarged a fuel hole and rejetted the carb a bit. I have no hesitation when I step on it and it runs like a scalded cat. Works great for my set-up.
Good luck
Old Mar 13, 2009 | 06:39 PM
Bear 45/70's Avatar
Bear 45/70
What is a fuel hole? Do you mean they put larger jets in it?
shadow_almanza
Apr 8, 2011 11:17 AM
James Campbell
27
Feb 1, 2007 02:40 PM
highboy 74
Aug 19, 2005 07:21 PM
