521 Cam question
Old Apr 7, 2011 | 10:47 PM
shadow_almanza's Avatar
shadow_almanza
521 Cam question
I just got back my 521 and they gave me the cam sheet and its states:
valve lift-.588/.588 int/exh
duration 302/310 int/exh
@.050" duration 234 int/242 exh
is this cam , small, mild, big i have zero knowledge about cams does anyone have a video of a similar cam?
Old Apr 8, 2011 | 08:06 AM
Greyman's Avatar
Greyman
That is a nice cam, could be a little bigger but on the street it will work great. I have a 562/588-234/244 in my 429CJ it pulls hard to the rev limiter at 6400. With your cubes it will calm it down a bit.
Old Apr 8, 2011 | 08:16 AM
704 dentside man's Avatar
704 dentside man
I'd consider that relatively mild, but should definitely help streetability.
Old Apr 8, 2011 | 11:17 AM
jtrux's Avatar
jtrux
My good friend has a 480ish CI motor in his '77 lwb 2wd F150 with a smaller cam in it and it runs like a bat out of hell, cant get enough traction anywhere, even when entering the on ramps to the highway. I think you will be extremely satisfied with that cam. Do you have a vacuum canister?
Just verified that my friend's cam is Comps 268H. Quite a bit smaller than yours. You will have a good time with that.
jmpage
Apr 15, 2017 08:10 AM
jeremy5wilburn
27
Jul 7, 2016 09:28 PM
NIdude
Apr 14, 2015 10:25 PM
Fellenz
13
Dec 8, 2013 11:34 AM
Boss50
Mar 17, 2013 09:51 PM
