Aftermarket Products
Sponsored by: Worksport
Back Up Sensor
Old Dec 12, 2002 | 01:12 PM
bricot's Avatar
bricot
Back Up Sensor
Anyone looked at the feasibility of adding the back-up sensor to an older truck? Can do? Huge pain? Can you even buy the units?
Old Dec 13, 2002 | 07:45 AM
steve83's Avatar
steve83
Back Up Sensor
http://www.atncorp.com/
http://www.parkingsensor.com/
http://www.promglobal.com/product.asp?dept%5Fid=27&pf%5Fid=00344
http://www.promglobal.com/product.asp?dept%5Fid=27&pf%5Fid=00536
http://www.reverseguard.com/
Old Dec 16, 2002 | 02:27 PM
13MWZ's Avatar
13MWZ
Back Up Sensor
AutoZone has one that you can install for around $50. A buddy of mine put one on his 83 Chevy 4x4. That thing is lifted to the sky and rides on 38's, so seeing behind him is a PITA. It works pretty good. The beeps get faster as an object get's closer, then when it's a few inches away it gets to a solid beep. Not hard to install either.
Old Dec 16, 2002 | 06:29 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
Back Up Sensor
[updated:LAST EDITED ON 16-Dec-02 AT 07:31 PM (EST)]DieselF350, Could you get me a part number on that please. I can't seem to find one. I really could have used on of these sensors when i backed into a tree. Doh!! Thanks in advance for your help.
Old Dec 18, 2002 | 02:24 PM
AlM's Avatar
AlM
Back Up Sensor
yo,
I bought the "Smartpark 2000 @ BJ's Club for $19.00. It is also sold under var. other names; but it appears to be discontinued. I believe BJ's still has a few left. as well as that jcw place; search for "back up"; but they want $60.
Here is a diy install on a passenger car.
http://www.ptdoityourself.net/ptautopark.html
It was simple to install on our 96 Bronco. We routed the wiring under lic. plate and along rear bumper (inside) and up through the rear fender aside the factory wiring harness to the right rear tail light assy. It was a good thing we did this because the factory harness was in terminal fraying stage bec. it was installed tight to the fender's sharp edge.
Old Dec 18, 2002 | 06:17 PM
jrs_big_ford_f150
Back Up Sensor
Cool, thanks AlM
Old Dec 19, 2002 | 09:02 AM
AlM's Avatar
AlM
Back Up Sensor
ok jrs,
BTW, forgot to mention it's working great! I always worry about the grandchildren and people, esp at night. And that buzzer is loud, if you get one, test it out in var. locations before installing the buzzer so it doesn't become an annoyance.
Old Dec 20, 2002 | 09:26 PM
DarylS's Avatar
DarylS
Back Up Sensor
arkredneck
Dec 18, 2013 07:59 PM
mrford60
Jan 1, 2010 03:06 AM
bswanzek
Oct 8, 2008 01:17 PM
hucka1a
May 31, 2008 01:14 PM
