Piston ring gap
Old Feb 8, 2009 | 10:56 AM
djmac's Avatar
djmac
Piston ring gap
I have an 92 EFI bore 60 over. I purchased speed pro molly piston (file to fit). I got the filing down pretty good around 15 strokes got me pretty close to .016 and I got carried away on one ring. On one lower compression ring I am up to .028 but I read that some recommend that lower compression a little wider anyway. So my question is do I have to replace the ring? Do I have to buy an entire set for an 8 cylinder? Also my oil control rings are around .025 out of the box. I believe that is within spec as is?
Old Feb 8, 2009 | 11:50 AM
mark a.'s Avatar
mark a.
I would get another ring.
Old Feb 8, 2009 | 02:27 PM
shortbed1's Avatar
shortbed1
Replace the rings on that piston you can get them individually. Go back to where you bought them. Chuck
Old Feb 8, 2009 | 05:33 PM
djmac's Avatar
djmac
Thanks guys, I will give Summit a call tonight.
Old Feb 18, 2009 | 05:52 PM
kotzy's Avatar
kotzy
The rule has been as far as I can remember been .003 to .004 per inch of cylinder, or 4 inch bore would be .012 to .016, compresion rings all the same. The scraper rails on a three piece oil ring not measurable as there is no way to support them on the spacer as they are in the ring groove. kotzy
Old Feb 18, 2009 | 08:04 PM
djmac's Avatar
djmac
thank you.
Old Mar 4, 2009 | 11:50 AM
Barry_R's Avatar
Barry_R
The big gap on a 2nd ring won't hurt a thing. We recommended going about .004-.006 larger than the top ring gap in the last Speed-Pro catalog. BTW - I wrote the last Fel-Pro performance catalog and the last four Speed-Pro catalogs...
Old Mar 4, 2009 | 02:35 PM
djmac's Avatar
djmac
Thank you!
72CC428
Jul 13, 2016 02:01 PM
Royson12
20
Apr 17, 2011 09:45 AM
Bueller
3.8 & 4.2L V6
Jul 19, 2010 10:41 AM
Tyler Burdett
24
May 12, 2009 09:50 PM
Fords&Farmalls
Aug 3, 2007 12:10 PM
