Turn Signal switch
Old Feb 7, 2009 | 03:35 PM
John Morton's Avatar
John Morton
Turn Signal switch
I am restoring a 52 F1. Can anyone recomend a good after market "Turn Signal Switch" to mount on steeing column? Thanks
Old Feb 7, 2009 | 04:38 PM
racoonbandit's Avatar
racoonbandit
I got mine from Sacramento Vintage Ford.
Old Feb 7, 2009 | 05:00 PM
Julies Cool F1's Avatar
Julies Cool F1
Yes, there is a switch that is sold on e-bay that I used on my 51 and it is very nice. It's easy to wire. The instructions are very good and I have a wiring diagram in Power Point if you decide to go that route. The switches come either chrome or black. The link I'm sending is for the cheapest one (Black at $20). Chrome are usually more.
Here is a link to the switch and the wiring diagram:
eBay Motors: FORD 46 47 48 49 50 51 52 53 54 TURN SIGNAL SWITCH **AJ (item 270338789900 end time Feb-08-09 22:30:09 PST)
You won't have any trouble finding one - I've just found e-bay to be less expensive in this case than the resto-parts places.
Good Luck,
Julie
Old Feb 7, 2009 | 07:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Signal Stat made the originals, and still does. NAPA sells them, they're not cheap but mine is 50+ yrs old and works great. Made in USA, I believe.
NAPAONLINE®
Old Feb 7, 2009 | 10:12 PM
tip49's Avatar
tip49
Turn signal switch
I used the after market sw mentioned; modified mounting by welding two tabs to column, that bolts sw to column. I also shortend the shaft of the hazard switch, and added '53 column shifter **** to turn assembly handle. I'll add picture to my gallery in a couple days.
Got to figure out wiring from hazard flasher, using harness from '90 Crown Vic.
Old Feb 7, 2009 | 10:19 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by tip49
...I used the after market sw mentioned; modified mounting by welding two tabs to column, that bolts sw to column...
I wish mine were that way. Nothing looks cheezier than a hose clamp holding the switch on!
Old Feb 7, 2009 | 11:39 PM
tip49's Avatar
tip49
Pic of handle
Poor picture but you can see the turn signal **** (oblong) I cut the end of the handle off and ground it down until **** pressed on.
Old Feb 8, 2009 | 08:11 PM
tip49's Avatar
tip49
better picture
Here's a better view of the signal actuator
Old Feb 8, 2009 | 08:54 PM
merten's Avatar
merten
Originally Posted by ALBUQ F-1
Signal Stat made the originals, and still does. NAPA sells them, they're not cheap but mine is 50+ yrs old and works great. Made in USA, I believe.NAPAONLINE®
I agree with Ross, Get the Signal Stat, a used one is fine. Mine came from an ebay auction and has an xtra wire for the single filament parking light to signal light circuit. I think it is a Signal Stat 900? It was only $20.00 with shipping. It is nice and heavy and has the emergency flasher built in.
Old Feb 9, 2009 | 09:50 AM
lonestaraggie's Avatar
lonestaraggie
I got my signal stat from the local napa store. There are several types but I used the heavy duty one meant for heavy trucks. It's extremely rugged and all metal. The wiring directions are easy to follow as well. You may have to buy a flasher unit and the socket to hold it, but it's still easy to use.
AJ
Old Feb 13, 2009 | 06:05 PM
tip49's Avatar
tip49
1990 Crown Victoria wiring
I'm re-wiring my '50 project, need help with wiring of turn signals and hazard flashers. I have the stock signal flasher assemblies for rear and front signal lights but unsure on wiring, one is dedicated to the front turns and cornering lights ? the other to rear. Do I bring power to turn signal switch out to the flasher units , then on to the turn signal lights ? Hazard flasher ( 2 pole) should come to the input of after market turn signal switch assembly, then out to ? there is a black (L) and a blue (P) input wires on turn switch; what do these letters mean?
Old Feb 13, 2009 | 07:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1
This has been posted many times before, and there are others in old threads. There is no such thing as a "stock" '50 turn signal AFAIK, they just didn't come with them. All were added on.
Old Feb 14, 2009 | 01:24 PM
HD74's Avatar
HD74
I found that Rhode Island Wiring offers a turn signal switch with period correct wiring if your going for original look.
Old Feb 14, 2009 | 02:14 PM
tip49's Avatar
tip49
"stock"
sorry for the confusion, I meant the stock 1990 donor wiring. If I interpret properly, the "P" pilot is the light for the hazard flasher and "L" load would be to the park/tail lights. I'll parallel the fused power to the L & P wires.
Thanks
zolav8
May 5, 2017 07:18 AM
philv
Feb 8, 2017 07:46 PM
Hwklein88
46
Nov 7, 2016 04:55 AM
460me
Apr 26, 2016 10:21 PM
marty277
Feb 17, 2016 04:56 PM
