Yet another VIN thread
On F500 and larger trucks, it can be located either inside the glove box door, or on the left door face below the latch (same as the pickups).
I posted some pics in a new thread. Thanks.
I have a 64 F750 that Im trying to Identify the transmission in so I can replace the synchronizer I found the pieces of laying in the bottom of her.
vin number:
F75KU567042
warranty plate information:
132 F750 F81B M H7 E
Net Hp - 176 @ 3800
DSO: 241039
Information on side of Transmission:
218016
K - CA - ER
Shift Pattern:
2 OD R
3 4 1
At first I thought I would have a borg warner t98a but there's a PTO opening on both the drivers side and the passengers side which made me think a new process. However the shift pattern is lending me heavily towards a clark.
I have a 61-66 series donor truck that I'm wondering if I could use the transmission out of?
her information is:
Serial number Trans Axle
F600N281186 F F 2
W B Color Model
174 J F600
Max G V W lbs Cert Net HP RPM DSO
17000 135 (or 155) 5800 24
Both trucks live at the family farm 4 hours south of the big city of Atlanta where I work and live. Any information you could give me from those numbers on both the F750 keeper and the F600 donor could save me several road trips now as well as in the future and would be greatly appreciated.
Also is there a chance the steering box from the F600 would be the same part as is in the F750?
Out of curiosity and wanting to be able to find this information on my own: Where is it that you get this information for the bigger trucks? FTE forum is the best resource I"ve found online so far for the classics but it doesn't have a lot of the little things for the bigger trucks that pop up continuously. Are yall looking in the shop manuals that I keep seeing mentioned? If so, where can I get one of my own?
Thank you again,
Emory,
vin number:
F75KU567042 warranty plate information: 132 F750 F81B M H7E Net Hp - 176 @ 3800 DSO: 241039
Information on side of Transmission: 218016 K - CA - ER
Shift Pattern:2 OD R | | | --------| | | 3 4 1
However the shift pattern is lending me heavily towards a CLARK.
her information is:
F600N281186 F F2
W B Color Model
174 J F600
17000 135 3800 5800 24
Are yall looking in the shop manuals that I keep seeing mentioned? Nope, Ford truck parts catalogs...see below for the info.
F75 = F750
K = 361 2V FT Engine
U = Louisville KY Assembly Plant
567042 = 1964, Assembled July 1964.
132" Wheelbase
F750 / 22,500 lbs. Gross Vehicle Weight Rating
F81B = Black all Vinyl
M = Clark Model 264VO 5 Speed Overdrive
H7E:
H7 = Eaton Model 17801 2 Speed Rear Axle / 6.50-1 & 8.87-1 / 18,500 lbs. Rear Axle Capacity.
E = Rockwell-Timken Front Axle / 7,000 lbs. Front Axle Capacity.
176 Net HP @ 3800 RPM
241039:
24 = Jacksonville FL Ford District Sales Zone Office, where the original selling dealr ordered the truck from.
1039 = Domestic Special Order Number
F60 = F600 2WD
0 = ? Should be C = 292 2V
N = Norfolk VA Assembly Plant
281186 = 1962, Assembled April 1962
F = Borg-Warner T-98 4 Speed Manual Transmission
F2 = Eaton Model 13802 Two Speed Rear Axle / 6.33-1 & 8.81-1 / 15,000 lb. Rear Axle Capacity.
174" Wheelbase
J = Rangoon Red
F600 / 17,000 lbs. GVWR.
17,000 lbs. Gross Vehicle Weight Rating
135 Net HP @ 3800 RPM
24 = Jacksonville FL Ford District Sales Zone Office.
C1TZ3504C .. Steering Gear Assy / Obsolete / Fits: 1961/62 F500/600
C4TZ3504L .. Steering Gear Assy / Obsolete / Fits: 1964/66 F500/750
GREEN SALES COMPANY in Cincinnati OH has FIVE = 800-543-4959.
I assume your present gearbox has "oceans" of play in it by now.
I may be able to find the internal parts new, saving you from buying one of those new gearboxes from high buck obsolete parts seller Green Sales.
Info sources: 1957/63 & 1964/72 FORD TRUCK PARTS CATALOGS
These two parts catalogs are available on CD's from hipoparts.com
