door panel
Old Feb 4, 2009 | 09:30 PM
moto4's Avatar
moto4
door panel
What is involved in taking the drivers door interior panel off to access the gears and track for the power window? This is on a ’00.
Old Feb 4, 2009 | 11:30 PM
Monsta's Avatar
Monsta
Sit. Stay.
Go get a 5.5mm socket, a flatblade screwdriver & a Phillips screwdriver.
Use the flatblade to pop off the reflector. This will access the bolt or screw...I can't remember which.
Use the flatblade to get in between the back of the power window switch "housing". Twist it so that it slides forward. (You may not need the screwdriver) Lift the front and pull out.
Undo the bolt (or screw I can't remember which) that you just exposed.
LIFT the panel straight up after you disconnect the electrical stuff.
There's a vapor barrier that you'll need to peel back to access the inner workings.
Old Feb 5, 2009 | 05:46 AM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Monsta good description, but a picture is worth a thousand words.
Door panel removal
Old Feb 5, 2009 | 01:19 PM
5150 MAN's Avatar
5150 MAN
I think its a 7mm socket on the door panel. About a month ago there was a thread asking for the same info. I replied a 8mm bolt and some else corrected me. But Monsta did explaine it right. the 5.5 mm is the size bolt/screw for the speakers in the doors. I just changed mine out.
Old Feb 5, 2009 | 01:24 PM
5150 MAN's Avatar
5150 MAN
https://www.ford-trucks.com/forums/index.php. If I did this right here is the thread I was talking about. hope it works.
Old Feb 5, 2009 | 01:27 PM
5150 MAN's Avatar
5150 MAN
I just tried it it did not wok, but the thread name was window problems. I hate to say I am Jack of all trades but master of none so a computer gets the best of me!
Old Feb 5, 2009 | 02:05 PM
Monsta's Avatar
Monsta
Sit. Stay.
Door panel removal
Yeah...MUCH better!
5.5mm is for the grill. Whoops.
And the Phillips screwdriver is to remove the panel on my Avalanche! oops, oops!
Old Feb 5, 2009 | 08:32 PM
5150 MAN's Avatar
5150 MAN
Monsta, those pics are in the thread I was talking about, thanks for you help. Moto, Make sure when putting the panel back on that all of the clips and lock **** all line up right! You will notice if one of the clips is not locked in the door because the panel will budge out a little. just slide it up a little and push it back down into place.
Old Feb 5, 2009 | 09:02 PM
moto4's Avatar
moto4
Thanks for the info. It doesn’t seem too bad. Now I just have to wait for a little bit warmer weather!
ZFamly
Jan 29, 2011 11:20 AM
chicagodragon
Apr 16, 2010 10:50 AM
billy13
Dec 14, 2009 10:29 AM
Ultramagdan
1997 - 2003 F150
Apr 10, 2001 08:17 AM
