hydraboost
Umm Guys, a little correction is needed here. Not that I give a chit. But just to make it sound like You know what Your talking about.
It's hydrOboost, not hydrAboost.
Hydra is a mythical, multi headed beast. Hydro is Fluid Driven.
So unless You have a Mythical Beast under the hood operating Your brakes......
Well i finally had time to install the (HYRDOBOOST) well everything went pretty much smothly up intill i had to bore out a bit of the slots were the two bolts to the brake master cylinder and then i still went the easy route n "T" of the return house with a brass t fitting ...filled the pump up with fluid... and there is a diffenent differece! cant wait to try it out when i start towing.
Oh and for the member that asked about the bumper im not sure what kind it is because it came with the truck when i bought it. but if i get a chance ill try and post a few more pixs tommorow.
You had to drill the holes in the master cylinder?
Mine was a direct bolt on, plenty of room.
With your truck being newer I would have figured it should swap right in easier than mine did.
lol ...yeah me too ... i put everything back and went to go to slide the master cylinder in to the hydroboost and it just wouldnt go in thats when i realized that the bolts coming from the hydroboost were just a bit apart from were the orginals were at... not a biggie though got my drill drilled it out to make it work ...
And yes it takes a lot less push to get the truck to a hualt! seems firmer too
Yeps, same here, only I used a Dremel tool to hog them holes out a bit.
20powerstroke02
Oct 2, 2015 09:57 AM
Mcroz
16
Nov 9, 2014 07:17 PM
