Power steering flush needed?
Old Mar 24, 2015 | 11:09 AM
20powerstroke02's Avatar
20powerstroke02
I have been noticing my brake pedal is very firm on and off also my power steering seems to get harder to turn than other times. But today i was sitting at a few lights and could hear my power steering pump growling at me intermittently if you want to call it that. Do you guys think a simple flush will fix this? Also sometimes my truck will pull to the left or right then it goes away if i hit the brakes again. I don't see how the hydra-boost system would do something like that. But its not the slide pins because i just greased those along with new brakes and rotors all around at the beginning of winter. I noticed when i grabbed my fluid lines going to the hydra boost from the power steering pump they seemed to rattle very rough so that makes me wonder if the pump isn't going out. How are the brakes supposed to be on these trucks? nice and soft? rock hard?
By the way truck is an 02 with 144k on it
Old Mar 24, 2015 | 03:39 PM
microdevil45's Avatar
microdevil45
As far as the flush goes here is a video by a member here. Good stuff on his channel check it out.
Old Mar 24, 2015 | 06:00 PM
carl2591's Avatar
carl2591
I did my power steering flush after watching that video as well. It was a good help and I would have used power steering fluid had i not seen this beforehand.
thanks tray.. he has another one on IPR rebuild which is top notch..
Old Sep 14, 2015 | 11:47 PM
kirkharrod's Avatar
kirkharrod
Wow! What a difference the flush made for me! No more whine and firmer brake pedal. The video was excellent. What is Trey's member name so I can rep him?
I went all out and jacked up the front and used the clear tubing. I did have to use an extra quart of ATF because I did let air get in the system! I just added another quart until the ait bubbles were gone. Another reason to use the clear tubing.
This is one of the easiest maintenance tasks that you can do on this vehicle.
Old Sep 15, 2015 | 07:49 AM
jhl3's Avatar
jhl3
Since it is growling, you should definitely give it a try. Flushing it out bought an additional 15k miles on the old pump.
Then it started growling at highway speeds and I decided to go ahead and change it prior to complete failure.
Ford will charge between $198-235 for the replacement pump. Better deals can be had elsewhere for about $55.
If you have to change it, be sure and get the specific pulley puller that you will find in the write-ups on here. It becomes important when you reinstall the pully.
AutoZ*ne has the puller for rent. Here is a link to an excellent thread:
https://www.ford-trucks.com/forums/7...ng-pump-2.html
Old Sep 15, 2015 | 08:17 AM
bigb56's Avatar
bigb56
My truck is also an 02 and when it had about 140K on it my pump started growling and whining. I flushed it and changed to synthetic and it's been great ever since. Matter of fact it's probably time to do it again.
Old Sep 15, 2015 | 09:48 AM
Mahir Sa'id's Avatar
Mahir Sa'id
i did mine the fluid in there was so nasty and old the smell of it was putrid but got it out i dont think i flushed it as much as much as i could but atlleast that old stuff is somewhat old i dont think its been changed
f250 2wd 7.3l long bed 310.xxx
Old Sep 19, 2015 | 12:32 PM
big poppa's Avatar
big poppa
I flush mine out at around 30,000 miles or so with Valvoline synthetic and it makes a BIG difference, braking, steering, no noise. At 263,000, knock on wood, still my oem pump. Changed the hoses at around 160,000 for prevenitive maintence.
Old Sep 19, 2015 | 10:18 PM
Stewart_H's Avatar
Stewart_H
Ford Truck Enthusiasts Forums - View Profile: A/Ox4
Stewart
Old Sep 30, 2015 | 03:40 PM
carl2591's Avatar
carl2591
synthetic like a mercon 5 type auto trans fluid.??
Old Oct 1, 2015 | 01:00 AM
scotttahoe's Avatar
scotttahoe
Yep, synthetic mercon V.
Watch out for the Valvoline MaxLife oil. I almost bought some the other day and it said Mercon V L or something close to that. My understanding is that you do not want run "L" in our trucks.
Old Oct 2, 2015 | 09:57 AM
rufushusky's Avatar
rufushusky
Maxlife ATF is valvoline cover all ATF... it is thinner at operating temp than Mercon V specs...
Petroleum Quality Institute of America
http://www.pqiamerica.com/MaxLife%20...%202-22-13.pdf
That said, I have run it in the past without an issue.
CarolinianFordLover
6.4L Power Stroke Diesel
Sep 1, 2016 08:55 PM
sdunn9
Jan 4, 2012 08:33 PM
tbirdage
Sep 9, 2010 11:06 AM
Reckless
Jan 5, 2010 11:54 AM
4sdahl
Oct 20, 2009 06:24 PM
