brake booster
Old Dec 1, 2008 | 09:40 PM
bakerbuilttracks's Avatar
bakerbuilttracks
brake booster
ok ive done alot of research on fixin my prolbem that has been going on for a while now. by looking through forms and searching i found some one who has had encounterd the same prolbems as i. its gotta be my brake booster. where do i get one that is a hydrabooster. i looked in a few shops online and all i found was vaccum boosters. where can i find a hydrabooster, how much are they and are they difficult to install
Old Dec 1, 2008 | 10:59 PM
sleek122's Avatar
sleek122
Here is a link to FTE Partsguy he is a sponsor. As for the install I can't help you there. Pricey little bugger but nice discount on it.
Old Dec 1, 2008 | 11:13 PM
Fordbronco69's Avatar
Fordbronco69
Infidel
baker ur truck got a noisy/humming sound? or ur brakes/steering fail completly?
My pump whines like a baby and im slowly narrowing it down to either the gear bohighly dougt it) and the hydro boost(will replace next weekend)
Ur gonna get a reman unless u buy a new one for like $500....im not trying to take away from FTE partsguy but the best deal i found is at orileys. $150+$50 core...cuz they got 5 stores within 50miles of FT HOOD.
All you gota do to replace is take the two nuts off the master cylinder let it fall forward, take off the 3 rubber lines, two will be fittings. Go inside and unclip the brake pedal from the rod and then the 4 nuts on the firewall then reverse for install.
Since u got the system open...ide go ahead and do a full flush with Mobil 1 SYN...it helped quiet mine down but she still cries.
Old Dec 2, 2008 | 09:42 PM
bakerbuilttracks
thanks fordbronc yea its a grinding vibration sounding noise. i replaced my pump and flushed w/ mobil syn atf. still got the niose. steering works and brakes work. i get the noise after its warmed up and after i come to a stop. sittin at a red light it starts as soon as i come to a complete stop. while sittin foot on the brake it starts let off it dies down accelerate it stops.. sound fimilar. after u install ur brake booster let me know if that fixes ur prob and i will do mine. thanks
Old Dec 2, 2008 | 09:50 PM
Fordbronco69
Infidel
ill let ya know..ill also do a write up on it...it might be the cure to all these noisey ps pump's some ppl have! 3 days left till the weekend
i got the same problem except when i first start the truck cold(sat overnight) i cant hear it, but as soon as i turn the wheel alittle or touch the brakes it whines. Im just hoping that it hasnt damaged my pump...wouldnt wanna have to replace that again!
Old Dec 2, 2008 | 10:02 PM
bakerbuilttracks
well heres the deal i found a thread which someone describes exactly what mine dose and never posted if the brake booster is the fix but here are my symptoms " At idle I can feel and here a grinding/vibration in what appears to be the power steering pump. Turning the steering wheel will make it change tones or go away, and increasing engine RPM's will make it go away as far as I can tell. The PS fluid level is good and I have no leaks. Further, the steering and brakes work fine, but his grinding is very bad" Its not a whinne from the pump its a grinding vibration."
Old Dec 2, 2008 | 10:17 PM
bakerbuilttracks
post back and let me know how the brake booster swap goes i will be out of town next monday through the 14th building a track in the boonies so i will check back this sunday befor i leave try and get some other inputs from people to see what they think too this has been going on for 6months for me and would like to get er fixed.
Old Dec 2, 2008 | 10:22 PM
Fordbronco69
Infidel
ive searched and searched, other sites also and found one...not sure if i can post the link ill send ya a pm of it and read it over....sounds like it sure fixed his noisy PS prob.
Old Dec 3, 2008 | 10:05 PM
bakerbuilttracks
dan said it could be the booster or the steering box they both recive hydro pressure
Old Dec 3, 2008 | 10:56 PM
Bergerson's Avatar
Bergerson
I too would like to know the outcome of this, mine is doing the same thing, very annoying!!
Old Dec 4, 2008 | 07:24 AM
vettdvr's Avatar
vettdvr
Exactly the problems I had when the transmission shop put power steering fluid in the ps pump. I had to totally flush the PS system with new fluid. Now it is running well. Before you spend big $$ you might consider changing/flushing the fluid. I removed the return line at the brake booster, routed it to a container and added new fluid with the engine running while pumping out. It took about 3+ qts to flush the pump/brake/lines and cooler. After this mine ran smooth.
Be sure to flush with fluid meeting the FORD spec for this appication from your manual.
Old Dec 4, 2008 | 09:14 AM
rbaker6336's Avatar
rbaker6336
Did you check for TSBs?
NHTSA Item Number: 6090315
Service Bulletin #: 7001
Replacement #:
Vehicle/Equipment Make: FORD
Vehicle/Eqipment Model: F250 SUPER DUTY
Model Year:
Mfg Component Code: 015100 STEERING:HYDRAULIC POWER ASSIST:PUMP
Date of Bulletin: 1999-09-01
Date Added: 2000-03-14
Summary: SOME TRUCKS EQUIPPED WITH A 7.3L DIT MAY EXHIBIT A NOISY POWER STEERING PUMP. *TT
99-2000 F-Series Power Steering Noise (part number correction):
Some of these trucks with the PowerStroke engine may exhibit power steering noise. If this noise is objectionable, there is a revised P/S line for between the P/S pump and Hydrobooster--YC3Z-3A717-AA.
Broadcast Message #8724
Old Dec 4, 2008 | 06:36 PM
Fordbronco69
Infidel
Im not sure about bakers problem but my truck NEVER made this noise until i got back from korea. just driving up to a stop sign bam started making it. So idunno...
Old Dec 4, 2008 | 07:41 PM
vettdvr's Avatar
vettdvr
Change the fluid asap. If that doesn't work,, change the pump!
Old Dec 4, 2008 | 07:56 PM
Fordbronco69
Infidel
2 napa pumps and like 5 flushes....with the 4th flush in a temp one day fixed it back to normal then back to the noise the next day!
