Loose steering
Old Jan 29, 2009 | 09:37 PM
itsjustagreat1's Avatar
itsjustagreat1
Loose steering
I forgot in my earlier post that I also have a play in the steering when driving down the road. It isn't terrible, but it is enough that you have to pay attn to. A few of my Ford buddies told me to tighten the worm gear or the other adjuster on the gear box. Are the correct? How do I go about adjusting the worm gear? I don't want to replace the steering box right now. Thanks again.
Old Jan 29, 2009 | 09:48 PM
RCrawler's Avatar
RCrawler
You need to have someone turning the steering wheel back and forth across the center and get under and look at the steering and suspension parts, including the steering shaft and connections, for play.
Is it lifted or stock height?
Jason
Old Jan 29, 2009 | 10:07 PM
itsjustagreat1
It is still stock height. The steering arms are new and ends.
Old Jan 30, 2009 | 04:05 AM
LCAM-01XA's Avatar
LCAM-01XA
There are like 4 different places on the steering shaft itself where play can develop (rag joint, slip joint, U-joint, and the tilt assembly), make sure all of these are good before you mess with the gear mesh load in the box as it's a great way to kill the gear box and in some instances yourself.
Old Jan 30, 2009 | 01:37 PM
RCrawler's Avatar
RCrawler
You also want to check the TTB arm mounting points, the spring shackles and spring bushings, axle u bolts. How are the ball joints?
Jason
Old Jan 30, 2009 | 07:38 PM
axel 56's Avatar
axel 56
I would take it to one of those shops and get the free quote on the repair a friend of mine gets his wife to take his in and then she says she has to let hubbie decide
Old Jan 30, 2009 | 08:48 PM
David85's Avatar
David85
Please don't adjust the steering box yet. What year is your truck? 2wd or 4wd?
Old Jan 30, 2009 | 10:14 PM
itsjustagreat1
Its an 85 4x4. I may have found the prob. Looks like when they put the tie rod ends on, the right one wasn't tightened all the way and now it is too loose to tighten up. Hopefully a new end will be tight and not have to replace the spindle arm (not sure what its called)
Old Jan 31, 2009 | 10:59 AM
axel 56's Avatar
axel 56
You are a lucky man!
Old Jan 31, 2009 | 12:02 PM
fonefiddy's Avatar
fonefiddy
No Doubt!!!!
seawulff
Nov 30, 2013 07:12 PM
Tomget
Jul 28, 2012 01:57 AM
alahil
Jul 1, 2010 11:08 PM
DirtyTace
Oct 26, 2007 08:11 PM
70T351W
May 27, 2005 11:42 PM
