I have had to use the same method and I can't use the smileys at all...... lol
Originally Posted by liftedgrocerygetter
Smart azz
I clear it every time I get off my puter, doesn't help me at all....
Originally Posted by RedBoat
Well I sent in an support ticket so lets see if Daves instructions work for me!!Nope still no smilies.
nope still no smilies lets try the double edit.
edit, edit,edit
Originally Posted by miller_feed
Nothing works for me on the posting page. I did all that was said, even defrag, and still no smilies..
I really don't have any input here, but thought I'd insert the smileys for those of you that don't seem to be able to.
Edit: Normal Edit.
Edited Edit: Still no problems. Don't see the issue. <--this one was done using Joes method....(this is also the 4th edit to this post)
Edited Edit Edit: BTW, Google Chrome here.
Reason: To show Joe it can be done...5th edit.
Edit: Normal Edit.
I saw the smilie in my post you edited and I was wondering how I did that, untill I read you post. (big smilie here). This is starting to (**** me off smilie here) make me mad.
Clear the internet explorer history and cache and edit will work again.
Tools
Internet options
general tabl
Browsing history
Delete
Several people have been having issues, this seems to fix it.
Smiliey's will also work after you clear the history.
OK... I'm game... I'll try it.
EDIT #1... OK, I have the "Save" "Go Advanced" and "Cancel" buttons showing up... and GUESS WHAT... can't get the edit saved. Now I'll try deleting my cache, etc.
EDIT #2... Cookies, Files, and History have now all been deleted, and ONCE AGAIN.... can't get it to save without using Joe's method!!
EDIT #3... I went straight to the "Go Advanced" route for this edit, and GUESS WHAT.... ... at least I can use the little smilies again, but it still sucks that I have to go through this double-jointed routine for editing a post and getting it re-posted.
First make sure you are logged off… then clear ALL your cookies, …then run-disk clean up check ALL and dump, then de-frag you HD restart and log in…
You gotta be fricking kidding me!!!
Tell me about it. The worst part was when I read I needed to log off after each visit! Do you know how ridiculous that would be? I come to FTE off and on about a dozen times a day. Logging in each time would be a HUGE, MAJOR PITA!
Now here's the kicker, I haven't had one problem with my laptop, from which I've been posting from tonight.
Subscribing to test the edit.
Edit one using IE as the default browser.
Edit two using IE and the "go advanced" window.
Edit three using IE and the "go advanced" window, adding smileys. and then previewed.
