Posting Pictures in Threads
Old Jul 30, 2005 | 06:12 PM
Earl's Avatar
Earl
The issue of how to post pictures in threads has come up often enough that I thought I'd put some notes in a sticky for your enjoyment (or torture if you're just getting the hang of using computers ). I'd recommend that you print out the instructions below and give it a try. If it works for you, do it about a dozen times until you can remember it without having to follow the instructions.
The first step is to get the pictures ready for uploading.
# The maximum image file size for your gallery is 3,145,728 Bytes, or 3,072 kB, or 3 MB. You should probably never need to upload an image larger than around 300 kB. Typical images run in the 25 kB to 100 kB range. (Note that the maximum image size for the Attachment feature, discussed below, is only 100 kB)
# The image file type can be JPEG (.jpg), GIF (.gif), or PNG (.png). I'd highly recommend JPEG files for most users. JPEG is the most common format used by cameras and image editing software.
# If necessary, use image editing software to size your images so that the width is less than or equal to 800 pixels, and the height less than or equal to 600 pixels. You can upload and post larger pictures, but it can cause horizontal scrolling issues on some of our members computer screens. Larger pictures also take up more storage, and usually don't make the image any more useful.
A simple, effective, and FREE image resizing program can be found here Photo Resizer. Download the program to your computer, unzip the file, and run the program to install Photo Resizer. Follow these steps to resize an image with Photo Resizer and set the appropriate picture quality for posting:
1. Start Photo Resizer.
2. Use the Open button to open the original picture file.
3. Set the quality to 20%.
4. If the image width is more than 800, set it to 800. Note that the image height may automatically change when you set the width to 800.
5. If the image height is more than 600, set it to 600. Note that the image width may automatically change when you set the height to 600.
6. Click on the Resize button.
7. Use the Save As button to save the resized image. Make sure the "Save as type:" is set to "JPEG Bitmap (JPG;JPEG;JPE)". DO NOT save the resized image over the original image! For example, if the original image file name is "Image.jpg", save the resized image as "Image - resized.jpg".
Now that you have your image resized and saved at a lower resolution suitable for web posting, you need to upload it and create a link in your post.
Club FTE members Club FTE members can use the Attachments feature when posting to directly upload pictures from their computer to their attachment storage area.
1. Start a post as you normally would.
2. When you are ready to attach a picture, click on Manage Attachments near the bottom of the post screen.
2. Click on the Browse button and find the picture file on your computer.
3. Click on the upload button to upload the file. Watch for any error messages (file too big, etc.).
4. Click on Close This Window
The attached picture(s) will not show up in the post preview window, but they will show up when you submit your post.
Linking to Image URLs If you are not a Club FTE member, or if you want to link to an image that is not on your computer, you can use the following procedure.
To insert an image in your post, you need to add text to your post that looks like this:
[IMG]URL[/IMG]
The [IMG] and [/IMG] parts of the text are simply HTML tags that tell the server that the stuff between them (the URL part) points to an image (picture). The URL is simply an address where the picture file is stored. It has to start with http:// for the FTE server to recognize it.
OK, so now you are saying, how do I get this URL thingy - the text that tells the server exactly where my picture is stored? Well, there are several ways to do it, but here is one fairly straightforward way for pictures in your FTE gallery.
1. Go to the "Galleries" button near the top of the screen, then click on "List" in the drop-down menu. Use the year and vehicle type to locate your gallery. Choose the album that contains the picure you want to post.
2. In your gallery albums, each picture has numbers below it that allow you to choose how big you'd like the picture to appear on your screen. Click on the number 2 below the image you want to include in your post. This will bring up the full size version of the picture on your screen.
3. RIGHT-click anywhere on the picture. A menu will pop up that has several options. Choose the "Properties" option.
4. Another window will now pop up showing a bunch of properties for the image - including the URL we want. Triple-click on the URL to select the whole thing, or, highlight the whole URL using the normal way you'd highlight any text with your mouse. Press CTRL-C to copy the URL text.
5. Click Cancel (or OK) to close the image properties box.
6. Exit your gallery.
7. Start your post in the normal way (post reply button when you are in a thread, or new topic button from the forum page).
8. Click on the Insert Image button (the button that looks like mountains).
9. Remember the URL you copied from your gallery using CTRL-C? Well, now press CTRL-V to paste that URL text into the pop-up dialog box.
10. Click OK to exit the pop-up box and you're done.
You can use the method outlined above for any image on the Internet - not just pictures in your gallery. As long as you can see the image full-size (not a little thumbnail version), you can right-click on it to get it's properties, copy the URL as described above, and paste it into the Insert Image dialog box. I find that opening a second browser window allows me to work with image URL's in one while I'm doing my post in the second one.
I'm happy to help with picture posting questions you may have. Just send me an e-mail and I'll see what I can do to get you up and running.
Old Jul 30, 2005 | 07:02 PM
B/B ford's Avatar
B/B ford
Clean & Classy
Thanks a lot George! That is just the kind of help I need getting around on this computer, much appreciated. Wayne
Old Jul 31, 2005 | 02:08 AM
Burt280's Avatar
Burt280
George you are the MAN. It's amazing how much knowledge one person can access and recall.....
Old Jul 31, 2005 | 06:05 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
George,
Once again you save the day!! I'll definately copy and save your instructions.....
....now if you can post instructions on how to overcome rectal-cranial inversion maybe I can be able to locate these instruction once I copy them and save them somewhere...
Thanks again
Bobby
Old Jul 31, 2005 | 06:59 PM
Randy Jack's Avatar
Randy Jack
George -
Thank you so much. I printed out a copy of the shorter instructions you put up last year, and they solved all my problems with posting then. But this has everything in it.
Printing now...
Thanks again!
Old Jul 31, 2005 | 08:53 PM
imlowr2's Avatar
imlowr2
Earl - Thanks so much. I like that picture software I downloaded. I haven't try to download a pic yet, but I'm sure I can do it, and have in the past. What I would like to do is put one of those little pictures next to my name? Any suggestions on how to to put that there? Thanks again Earl.
Old Jul 31, 2005 | 09:15 PM
Earl's Avatar
Earl
The images next to names are called Avatars. In the next couple of days, I'll try to put together a sticky on setting one up. Stay tuned ...
Old Jul 31, 2005 | 09:17 PM
imlowr2's Avatar
imlowr2
I think I got it Earl. However the picture isn't very clear? LOL... Ed
Old Jul 31, 2005 | 09:23 PM
Earl's Avatar
Earl
I'll try to address how to minimize that effect. Hope it will help.
Old Aug 3, 2005 | 12:33 PM
bluestarva's Avatar
bluestarva
Thanks for the info. It reallly helps us newbees.
Old Aug 6, 2005 | 06:10 PM
Burt280's Avatar
Burt280
Success
I just did my first post with pictures....and it worked ...... I feel so smart ...
Old Aug 8, 2005 | 06:12 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
VERY VERY nice George
Old Aug 8, 2005 | 09:57 AM
8Flat's Avatar
8Flat
Hey George, I can't get to my gallery to edit it, this has never happened, any ideas? I can edit all my other info, but not the gallery, it comes up with an error code message:
Warning: main(../header_css): failed to open stream: No such file or directory in /page_header.php on line 11
Fatal error: main(): Failed opening required '../header_css' (include_path='.:/usr/local/lib/php') in /data/httpd/ford-trucks.com/htdocs/user_gallery/page_header.php on line 11
THanks,
Gary
Old Aug 8, 2005 | 10:23 AM
Earl's Avatar
Earl
Gary, best I can tell, the servers are having a problem with the gallery display. It should be fixed shortly (we hope!). Sorry for the inconvenience.
Old Aug 8, 2005 | 11:20 AM
8Flat's Avatar
8Flat
No problem, thanks for the reply. I've waited 6months for my flathead, so waiting another day to post pics shouldn't kill me...
