Sponsored by: Real Truck
Still no braking !!!!!!!!!
Old Jan 28, 2009 | 05:05 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I have no clue. Haven't needed to do it yet.
Old Jan 28, 2009 | 05:15 PM
doctor_ratz's Avatar
doctor_ratz
I bled the heck out of the system, thinking that there may be some issue with air, but it didn't seem to help.
However, something you said does make some sense. The pedal does go a long way towards the floor, and does almost feel like there is air in the system. At a stand still, I can just about bottom out the pedal, but I was unable to bleed any air from the system.
I will have a look at the ABS tonight.
I have heard that if you force the caliper piston back into the caliper while doing a brake job, you can damage the ABS solenoids. When I put the Hawk brakes in, I noticed that someone had recently replaced the pads. I oppened the bleeders to release the pistons, but there is no guarantee that the last guy did the same. Any thoughts.
Old Jan 28, 2009 | 06:35 PM
Beerstalker's Avatar
Beerstalker
Originally Posted by BPofMD
The Ford trailer brake controller does NOT work with electric over hydraulic trailer brakes!! Prob why it doesn't work well. How does it do WITHOUT the trailer?
He's got a 2000, so he doesn't have the integrated brake controller.
Also, it's not that the integrated brake controller doesn't work with electric over hydraulic brakes, it's that it's not guaranteed to work. It works with some and doesn't work with others. Ford doesn't have the time or money to go out and test it with every different kind of electric over hydraulic system out there so they put in a disclaimer that it is not guaranteed to work with them. Since electric brakes all work pretty much exactly the same they know if it works on one it will work with them all so they do say that it is compatible with them.
Old Jan 28, 2009 | 10:08 PM
krewat's Avatar
krewat
Not true. You might force DIRT back into the ABS unit, which can cause this.
Old Jan 29, 2009 | 09:45 AM
doctor_ratz
I just got off the phone with the local Ford service manager. He said that there is a possibility that there is air trapped in the ABS unit. To remove the air, you need to bleed the system with the ABS activated.
He also said that he has had many complaints regarding poor braking performance on Ford SD's. Some of the complaints he has been able to fix, others he hasn't.
The other tip he offered was to make sure the alignment pis on the calipers are free, and lubricated with anti seize. These pins are available at Autozone for a couple bucks. I replaced all of them, but it didn't seem to help much.
Old Jan 29, 2009 | 02:21 PM
krewat's Avatar
krewat
I hear an echo But yeah, bleed the system, it might have air in it, or any dirt trapped in the valves will be bled out.
Let us know how it turns out.
acamk37
Feb 19, 2015 11:05 AM
MadMedic20
Aug 6, 2010 09:38 AM
pauldahle
Dec 26, 2007 06:11 PM
1madison
1997 - 2003 F150
Dec 8, 2001 07:48 PM
lt
Apr 12, 2001 10:01 AM
