Hey Everyone, New to the Superduty side. (Used to have an F150). I am going to pick up my brand new used 2000 F250 crew cab on Friday and am going to get my 4" suspension lift ordered, as well as my wheels/tires. I plan to buy the Eagle 589 style wheel in 16x10. I was just wondering what backspacing they should have? I don't mind if the stick out past the wheel well a little. Just didn't want them sticking out very far. Tried to do a search and came up with 4.5". Is that about where they need to be? Thanks!!!
That will stick out about 1" with a 12.5" wide tire. I have 5.03" backspacing on my 10" wide wheels with 35x12.50s and they stick out about 3/8" and clear the leaf springs by about 1". How wide of tire are you planning on getting? 10" is pretty wide for a 16" wheel in my opinion, my old wheels were 16x8 with 4.5" backspacing and they set 315/75/16s just a hair outside the fender. The same backspace on a 2" wider wheel will move the tire out 1".
The tires are 35x12.50x16's. I have always ran a 10" wide rim with that size of tire. I like the look of the wheel and I think a 12.5 tire looks better on a 10" wide rim. So 5.03" is what you recomend?
I've been looking at the Icon lifts on Dan's website from some time now. I was thinking about the 4.5" lift with 1" front spacer and 5" rear springs. I do plan to replace the front and rear bumpers with Alien Patrol bumpers. I don't know if this will work or not...
Had to trim the lower valance of the front bumper. He drives on road mainly...and a lot, no rubbing.
More off road use and they may rub.
Yes, I like that look! However, I think that I'll do the 7" lift to be on the safe side. I plan to do the bumper first, then the lift kit. I'm definitely going with Icon. Thanks Dan!
