Custom Cab Options
Old Jan 26, 2009 | 05:36 PM
dullchrome's Avatar
dullchrome
Custom Cab Options
What exactly were all of the Custom Cab options for the 61-99 f100s?
Old Jan 26, 2009 | 07:24 PM
camperspecial65's Avatar
camperspecial65
Custom Cab package existed only thru 72 as I recall..package composition is in my gallery...go have a looksee......
- cs65
Old Jan 26, 2009 | 09:17 PM
dullchrome's Avatar
dullchrome
Sorry, I ment 61-66. Fat fingers hit the wrong number.
Old Jan 27, 2009 | 05:12 PM
Customcab's Avatar
Customcab
Just wanted to add; does the model body type (identifcation tag) determine if its a true customcab body?
Like E81 verse said a B81????
You see so many version of assesories on these trucks'; I usually try to determine a customacab mainly by the front windshield trim & speedo. but that can't always be the determining factor either. Because unless your the Originial owner "who knows"
Mitch
Old Jan 27, 2009 | 05:50 PM
dullchrome's Avatar
dullchrome
so a true custome cab has to have all of those options or could the original buyer pick from the list of options?
Old Jan 27, 2009 | 06:20 PM
camperspecial65
For the vast majority, the package composition as shown in my galley and literature is gospel...BUT there have been slight deviations over the years...on these trucks the DSO would NOT be the standard 2 digit code denoting a regular production vehicle.
These specially trimmed or equipped trucks would have a 6 digit DSO code...firat 2 are the DSO(where original selling dealer ordered the truck from) and the last 4 is the actual order number used by Ford and the plant to keep track of paperwork.
Then there are alot of things seen in these trucks which are part of SOME packages and not offered on some but offered as a dealer installed option for all...the best example and most common I believe would be the inside door storage compartments.
As to the door tag denoting a Customcab trimmed truck...the letter or letters in front of the 81 do indeed denote a Custom cab truck...if there is a number in front of the 81...or whatever body type number the truck is, the number denotes a base model truck...aka...stripped down version.
- cs65
Old Jan 27, 2009 | 06:36 PM
dullchrome's Avatar
dullchrome
My truck has the door storage compartment, bright metal grill/headlight assembly, windshield moulding, door handles, horn ring, perferated headliner, sun visors, cig lighter and one arm reast,but that is all.
No scuff plates, door panels , door trim moulding, headliner moulding or passenger arm rest.
Does that sound right?
Old Jan 27, 2009 | 06:57 PM
camperspecial65
In 1963, the driver armrest was standard as I recall...the RH was optional. It sounds like you prolly also have the 2 piece headliner too...the Custom cab script would have 6 small holes in the center of the upper area of the door...it may also have had Custom Cab door handle bezels...this would be on trucks WITHOUT side trim...trucks WITH side trim got the door nameplate script instead of the door handle bezels.
If your truck, being a 1963, has the door tag on the rear of the driver door face thats NOT its original door...on 1963s the tag was on the glovebox door.
- cs65
Old Jan 28, 2009 | 04:25 PM
dullchrome's Avatar
dullchrome
- cs65
Why would it be necessary to relocate the tag from the glove box lid to the door face?
Old Jan 28, 2009 | 05:54 PM
garbz2's Avatar
garbz2
Bad Info
"being a 1963, has the door tag on the rear of the driver door face thats NOT its original door...on 1963s the tag was on the glovebox door."
61 has a Vehicle identification tag plate on the glove box door.
62 has a Warranty tag on the glove box door.
63,64,65,66 all have the warranty tag on the drivers door just below the latch...
Garbz
Old Jan 28, 2009 | 06:57 PM
camperspecial65
You are correct Garbz...after looking at an old plate I saved from a scrap door..it was a 63 rig...an early one at that...9/62 build date.
- cs65
Old Jan 28, 2009 | 07:39 PM
garbz2's Avatar
garbz2
I have found the plates all over the truck, even riveted to the dash, The locations i posted are right out of the ford shop manuals. It helps to know where there at when looking at a truck that has a, AHEM disagreeable pedigree. I once really pissed a guy off selling his 100 percent original and priced accordingly 64 F250 4x4 with a F10 Vin number and a mated 2 speed case..I never knew ford installed 74 frames under 64 sheet metal in 1964 on 2 wheel drive trucks...
I have also bought trucks with warranty tags on the door and on the glovebox lid.. and neither of them matched the frame or the title...Avoid bill of sale states....
Look on a 61 tag it has vehicle identification number all other years say Vehicle Warranty number..
Garbz
Old Jan 28, 2009 | 08:23 PM
Customcab's Avatar
Customcab
I've found metal data tag's inside the rear taillight housing on acouple trucks as well.
Mitch
Old Jan 28, 2009 | 08:53 PM
garbz2's Avatar
garbz2
Mitch
An actual printed tag or the aluminum tag that was given to you when you purchased the tuck new with the owners manual?
I have the plain imprinted aluminum tag my dad received along with his Owners manual and paperwork. The were glued to a plastic card.
I have even seen these pop riveted to the door.
Garbz
arvet19
Jul 19, 2017 08:26 AM
6t6merc
Jun 12, 2016 07:37 PM
Amphihauler
May 30, 2016 02:15 AM
W7PSK
6.7L Power Stroke Diesel
Feb 17, 2012 11:58 AM
roadshowbob
15
Feb 1, 2010 08:03 PM
