VIN decode
Old Jan 27, 2009 | 10:29 PM
Shorty 66's Avatar
Shorty 66
VIN decode
Please help decipher.F10JR592258WR. 115 Color. N/A Model.F100 Body. 481 Trans. F Axle. 09GVW. 5000 HP. 129 RPM. 4000 DSO. 510167Thanks
Old Jan 28, 2009 | 06:54 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F10 = F100 2WD
J = 240 1V I-6
R = San Jose Assembly Plant
592258 = 1965 (WR? The VIN is only 11 digits thru 1980).
115" Wheelbase.
No Paint Code listed.
F100 = F100 2WD / 5,000 lbs. GVWR
481: 4 = Light Beige Crush Vinyl & Light Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
F = Warner 4 Speed Transmission, either a T18 or a T98.
09 = Ford 9" Rear Axle / 3.70-1 / non Limited Slip / 3300 lb. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
129 Net HP @ 4,000 RPM
DSO 510167 =
51 = Denver CO Ford District Sales Zone Office, where the original selling dealer ordered the truck from.
0167 = Domestic Special Order number.
Your truck was special ordered from Ford, it may be because it was painted a non standard FoMoCo color, why no color code is listed.
The 4 speed was a RPO = Regular Production Order, so it was not a special order item.
Old Jan 28, 2009 | 11:02 PM
IsoGrifo's Avatar
IsoGrifo
hey ND, isn't that the CC seat pattern in a standard cab?
Old Jan 29, 2009 | 12:57 AM
NumberDummy
1965
481 = Light beige crush vinyl, light beige wicker pattern vinyl // 81 = 81A Standard Cab.
281: Same as 481 except in blue.
381: Same as 481, except in green
581: Same as 481 except in red.
D81: D = Light Beige Crush Vinyl & Medium Beige Ladder Pattern Woven Plastic // 81 = 81B Custom Cab.
Usually, if the body code begins with a number: Standard Cab.
With a letter: Custom Cab.
Old Jan 29, 2009 | 01:58 AM
camperspecial65's Avatar
camperspecial65
IsoGrifo..I posted a comment on a thread as to the same issue...the material used on mine is also used in 66 trucks, and not just the pickups either...but its also not a CustomCab only material as I had thought for a long time...as its also used in the base model trucks. If one has the parts books and finds their particular name for the seat material and go looking throughout the list...the material is used on many rigs...mine also found its way into some E series rigs as well...all with different trim codes...but same product name and description...its royally confusing...and mind boggling...even moreso if one doesnt have the books and sees a different model or year truck with the same material as in theirs.
- cs65
Old Jan 29, 2009 | 02:12 AM
NumberDummy
- cs65
1965: 481 = F100/1100 // N/NT/T500/1100 (81A).
I agree, it's (somewhat) mind boggling with the parts catalog. However...
Without the parts catalog, one can't do diddly squat when it comes to decoding any Warranty Plate info.
