Fellas/Ladies.where can I find the green o-rings for the two tubing lines going to the side of the injector pump besides Ford?Have the part number?..I think one is oil and the other is fuel?I use to have some and have missed placed them...Thanks
Not trying to be insulting, just trying to figure out what you're working on. Also, Ford's o-rings have changed color over the years, so what is green for you might be black or brown or yellow for me.
2002,F350 7.3....Hell..o.k.The pump under the plastic Powerstroke sheild.
Are you talking about the fuel filter bowl? I'm just up the road in Grandview and I have some O-rings. If we can figure out which ones you need, I may be able to help out with what I have on hand.
Chris...That is the lines.I need the o-rings for them.I will look at Guzzle.I have a full replacement for the bowl/filter housing...Thanks to all who helped
