Not hrottle when cold...?
Old Jan 24, 2009 | 10:42 PM
dyhrdford's Avatar
dyhrdford
Just like the title says, (even though there is SUPPOSED to be a "T" in front of "hrottle")when it is really cold (15 or less (aprox)), I will start my truck. When I give it any throttle, its like Im not touching the pedal at all. This only happens when I start it when it is stone cold. I never have any problems any other time. I am wondering if this is built into the ECM to prevent damage from running hard while cold?
Thanks, Aaron
Old Jan 24, 2009 | 11:06 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Thanks, Aaron
Nope, no such thing. I have never seen it, though the coldest I have ever started the truck is about -5F.
cleatus12r's Avatar
cleatus12r
Butt-Head
To the OP....
That's normal.
Old Jan 24, 2009 | 11:15 PM
Tenn01PSD350
Originally Posted by cleatus12r
To the OP....
That's normal.
What do you mean? The first 5 seconds? My throttle worked when I had the romps. As soon as it started, my pedal worked. Is my truck an exception? To this day I can rev it within seconds of starting if I want to.
OK, I reread his post. If we are talking about the way there is no throttle when cranking/starting, I might go for that, though I have not tried that either.
Old Jan 25, 2009 | 12:18 AM
parkland's Avatar
parkland
it will not respond because the oil is too cold.
if it is this cold, you probably should let her warm up before driving.
I had my truck at work once, and it was -35 with 90km/h gusts, and even with the block heater, and cycling the plugs a few times, she barely started, then it was 2 minutes before the throttle even made any difference.
In fact, it was so cold, that on the way home, i went down a hill and let off the throttle as to maintain speed, and at the bottom, my temp guage was almost bottomed out.
Moral of story= if it doesnt want to drive, dont force it.
Old Jan 25, 2009 | 12:31 AM
MTDewX's Avatar
MTDewX
I use custom Cardboard and a bungi (on the grill) to help keep my engine warmer while driving.
but my truck wont even start below 20 deg if not plugged in for at least 4 hours.
and our high this weekend I think is 5 above. all is good once started though
But always let her warm up a bit cause not much like to work at that cold temps.
Old Jan 25, 2009 | 12:39 AM
parkland's Avatar
parkland
I thought of doing this a while back, but a guy i know did this and blew a rad hose going up a hill.
The problem is that our engines make F-ALL for heat, but then you put the fuel to em and they heat up like crazy.
Old Jan 25, 2009 | 01:45 AM
DCSpecial's Avatar
DCSpecial
What oil are you running?
Old Jan 25, 2009 | 02:19 AM
orng1's Avatar
orng1
I love living in SoCal, it was raining today and it was still around 60.
Old Jan 25, 2009 | 10:27 AM
randomhero1172's Avatar
randomhero1172
its completely normal - Its too cold to function basically. happens to be all the time when i start it without the block heater plugged in in 5* to -15* F
