Major Problems with Starting System
Old Jan 23, 2009 | 04:41 PM
78_4x4's Avatar
78_4x4
1978 Ford F150 4x4 460
Problem: Starter keeps cranking over
New starter, new ignition switch and module, many new solenoids, new battery.
is there any kind of control unit in the system that could go bad and cause this??? What is inbetween the solenoid and the ignition module???
Lost and confused. Please help!!!!!!!!!!!!!!!!!
Old Jan 24, 2009 | 11:52 AM
fmc400's Avatar
fmc400
MSEE
The next time this happens, pull the wire off the 'S' terminal on the solenoid, and see if it keeps cranking. Post back your results.
Old Jan 24, 2009 | 02:46 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
So you've essentially replaced everything and the problem still exists? That is interesting, as there is nothing more to the system. Unless you have a wire grounding out, possibly the "S" wire as stated above?
Josh
Old Jan 24, 2009 | 03:06 PM
Goader's Avatar
Goader
Ignition switch. It's got 12 volts going to it. If it shorts to the start circuit than you have completed the start circuit without turning the key. Just a thought. I had to test mine recently. I had the luxury of having an extra switch lying around so I just unplugged the old one and put this one in and turned the key. If you have a volt meter than unplug your ignition switch and and look at the terminals. They will tell you what is 12 volts going in and the circuit it goes out to. Put it back together and try a continuity test. This should test the switch and the plug that goes into it. Of course if you see any melted plastic than, well you know.
Old Jan 24, 2009 | 05:58 PM
Bullitt390's Avatar
Bullitt390
True, but he said he replaced the switch.
Josh
Old Jan 24, 2009 | 11:52 PM
critter119's Avatar
critter119
have you check the wiring from the ignition switch to the s-terminal on the solenoid. i have had the issue of it getting shorted to power on one of my friends vehicles. that is where i would look do to the fact that it keeps cranking after you have replaced all of those parts. it may be that a mouse could have chewed the insulation off of the wiring
Old Jan 25, 2009 | 03:07 PM
Goader's Avatar
Goader
Josh
He He. Missed that one. However the plug that goes into the switch is the problem I had. Wound up cutting all the wires and replacing the whole plug as it had melted and shorted.
Old Jan 25, 2009 | 03:15 PM
1977f250's Avatar
1977f250
do you have a solenoid on the fender as well as on the starter?
Old Jan 26, 2009 | 08:13 AM
Bullitt390's Avatar
Bullitt390
Do you know what caused the melting?
The only problem I had with the switch was if the dirt road had a bad enough washboard it would shake the switch and turn the truck off.
Talk about annoying when that road was my way home for 8 years.
Josh
Old Jan 26, 2009 | 03:00 PM
Goader's Avatar
Goader
Never figured out what the cause was. As a matter of fact it took me a while to figure out that it was the plug. All I remember is that one day I was driving down the road and I smelt what I thought was something electrical burning or getting hot. I looked down and didn't see any smoke or other indication so I passed it off as something in the outside air.
Old Jan 26, 2009 | 04:04 PM
Bullitt390's Avatar
Bullitt390
Try driving down the road with the heater on full blast with the vent closed off.
Whoa did that smell! I totally thought it was my brakes dragging it smelled so bad.
Josh
Old Jan 30, 2009 | 08:29 AM
78_4x4's Avatar
78_4x4
Old Jan 30, 2009 | 09:52 AM
fmc400's Avatar
fmc400
MSEE
Originally Posted by 78_4x4
Well, we've given you several suggestions, and you haven't posted back with any test results.
Old Jan 30, 2009 | 05:52 PM
Alvin in AZ's Avatar
Alvin in AZ
Yep, FMC, sometimes I miss the freedom of speech of newsgroups.
It'd be with both friggin' feet and wouldn't be pretty neither.
Alvin in AZ is a butthead
Charlie Doc
Modular V10 (6.8l)
Jun 12, 2014 04:08 PM
Thunderhorn
1978 - 1996 Big Bronco
Feb 4, 2014 11:30 AM
AK F150
Nov 17, 2003 09:48 AM
joners
Electrical Systems/Wiring
27
Jun 29, 2003 10:15 PM
fuzbuster
Mar 14, 2003 10:44 AM
