Modular V10 (6.8l)
ford racing v10 headers????
Old Jan 18, 2009 | 05:14 PM
Bladely's Avatar
Bladely
Has anyone heard about them, are they good? The application guide says for model year 2004, mines a 2002, is there a difference? $379 seems like a good price considering their from Ford.
Ford Racing Performance Parts [M-9430-SD682C*]
http://www.fordracingparts.com/image...430-SD682C.jpg
Old Jan 18, 2009 | 05:42 PM
SID297's Avatar
SID297
I had two sets and sent them both back. They were poor quality. I'll be going with a set of JBAs.
Old Jan 18, 2009 | 06:54 PM
Bladely's Avatar
Bladely
What make them bad, poor construction or finish or what? Thanks for the imput.
Old Jan 18, 2009 | 07:48 PM
Fordfanatic4life's Avatar
Fordfanatic4life
i thought a well designed header tried to equalize the length of each runner..
that design doesnt appear to do that at all..
Old Jan 18, 2009 | 08:30 PM
SID297's Avatar
SID297
All of the above, especially poor construction.
You are correct.
Old Jan 19, 2009 | 10:30 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
"shorties" do not ... the cheapo ebay headers I bought are "shorties".
The problem with "well designed" and "equal length runners" is the length of the runner, and the diameter. Both determine where the header helps the most in scavenging exhaust from the cylinders. Banks is expensive, but seems to do the most in that department for TOWING, at least that's what most people think.
Old Jan 19, 2009 | 05:17 PM
Skoda's Avatar
Skoda
there is very few situations were you would end up(Ideal set up) with an equal lengthed header, first things to look for when even considering an equal lengthed header is firing order for that one bank. It should be equally spaced, now. . . I'll shut up I've said too much already
Old Jan 19, 2009 | 05:25 PM
dkf's Avatar
dkf
I have pics of my Thorley headers in my gallery. They are close to equal length but not exact. I've seen equal length shorties for mustangs and they are all twisted up like a pretzel.
Old Jan 19, 2009 | 05:40 PM
Skoda's Avatar
Skoda
My mistake I was reffering to the primaries, not the complete "header"
Old Jan 19, 2009 | 05:45 PM
krewat's Avatar
krewat
The V10 is an even-firing engine. First, it fires each cylinder exactly 72 degrees apart. Which makes it the definition of "even fire". (A little history: The Buick V6 that is known as an "odd fire" actually used what looked like an 8-cylinder distributor cap with two posts missing. It actually had a huge gap in two places)
Then, it fires from bank 1, and then bank 2, and back to bank 1.
1-6-5-10-2-7-3-8-4-9
So, with the V10, it's VERY possible to get an equal length header that actually does it the "right way".
On the Ford FE series, like the 360 and 390's in many many pickup trucks out here, it actually fires two cylinders in one bank one right after the other. Making truly "scavanging" headers almost impossible to make unless you cross over from one bank to the other.
Old Jan 19, 2009 | 11:43 PM
oldirtytruck's Avatar
oldirtytruck
seems like it would just be easier to wield you own headers
Old Jan 20, 2009 | 04:22 AM
Skoda's Avatar
Skoda
very interesting
Old Jan 20, 2009 | 06:49 AM
System's Avatar
System
Prolocutor
This is why the 10's sound like 6's when you try to do an aftermarket exhaust. It's the odd fire that gives the 8's their rumble.
Old Jan 20, 2009 | 11:00 AM
krewat's Avatar
krewat
The 4.6 and the 5.4 fire bank-to-bank. The FE I used as an example is still an EVEN-FIRE engine. It just doesn't fire bank-to-bank, it has certain cylinders in ONE bank firing right after each other.
Old Jan 20, 2009 | 12:02 PM
Bladely's Avatar
Bladely
Thanks for all your help guys. I really appriciate it.
