quick relay?
Old Jan 18, 2009 | 06:48 PM
1dieselman's Avatar
1dieselman
Getting any tailpipe smoke, I don't remember what fuse drives the injector computer, was thinking its a maxi fuse.
Old Jan 18, 2009 | 06:56 PM
Tommy_Mills's Avatar
Tommy_Mills
No It Would Have To Be The Whole Connection On One Side Or The Other. If One Connection Is Loose You Dont Have Anything On That Side. It Wont Fire With Only One Bank Connected.
Old Jan 18, 2009 | 07:04 PM
1dieselman's Avatar
1dieselman
This truck should have two connectors on each bank so it should start if one connector is undone
Old Jan 18, 2009 | 07:06 PM
Welk49's Avatar
Welk49
Fuse for IDM is good, still no tailpipe smoke, so the fuel is not getting through the injectors.
Old Jan 18, 2009 | 07:10 PM
Tommy_Mills
Injector Driver Itself Possibly. Not Very Common But I Have Seen It Once
Old Jan 18, 2009 | 07:13 PM
Welk49's Avatar
Welk49
I am hoping that's not it, I hope it's something simple, but at this point I just want the damn thing fixed and running again.
If it is the IDM how could I make sure it's bad? I don't want to replace parts for the sake of it especially something that's going to cost m over $300
Old Jan 18, 2009 | 07:17 PM
putz54143's Avatar
putz54143
have you topped off the high pressure oil pump, or checked to see if its full
Old Jan 18, 2009 | 07:19 PM
Tommy_Mills
They Arent Very Fun To Get At. Drivers Side Fender Well If I Remeber Correct. Did You Say That You Checked The Crank Sensor? If You Did, Or If You Replaced It, Its Not Out Of The Question That The New Sensor Was Bad Right Out Of The Package. Ive Seen That As Well.
Old Jan 18, 2009 | 07:22 PM
Welk49's Avatar
Welk49
I replaced the CPS, when I crank the engine it registers on the tach. Haven't checked HPOP they guy who had it before stripped the allen plug out so I have to go get a wrench big enough to take the sensor out of the top of it to check it
Old Jan 18, 2009 | 07:28 PM
putz54143's Avatar
putz54143
do you know anyone else with a psd? if you can borrow his idm and try it takes 5 min to take it out drivers side fender 3 small bolts and the pulg is also fasten the a bolt . i had a bad one but my truck still ran, just run like crap
Old Jan 18, 2009 | 07:39 PM
1dieselman's Avatar
1dieselman
x2 that, you might disable the GP relay a give it a sniff of starting fluid
Old Jan 18, 2009 | 07:40 PM
Welk49's Avatar
Welk49
got a buddy coming over tomorrow who has same truck, will try his and see what happens
Old Jan 18, 2009 | 08:48 PM
  #28
Welk49's Avatar
Welk49
after researching my problems I have found some guys with same symptoms. I am going to check wiring to IDM, and connections at IPR tomorrow and see what happens
Old Jan 18, 2009 | 09:14 PM
  #29
2 stroke man's Avatar
2 stroke man
for laughs, check your fuel pressure if you havent. could be getting it to bowl, but not ebough pressure to fire.
brcwelding
Sep 30, 2012 08:21 AM
bobwhyte2002
May 6, 2012 10:30 PM
400 .040over
Apr 3, 2012 01:16 PM
Jaaaaaaackman
Nov 14, 2008 07:05 AM
captin.kid
Electrical Systems/Wiring
Mar 5, 2006 08:39 AM
