Relay for 130w lights
Old Mar 4, 2006 | 07:14 PM
captin.kid's Avatar
captin.kid
It there any such relay all the relays that i have been looking at say 55w. I have heavy duty wire but need to know if the relay will work?
Thanks
Old Mar 4, 2006 | 07:45 PM
Howdy's Avatar
Howdy
The square black cube relays are usually rated for 20-30 amps. Your 130W lights will draw a hair over 10 amps each, worst case. Have you been looking at the little rectangular relays with 8 pins? Those are usually good for 4 or 5 amps, which seems to be what you are descibing. Most parts stores sell the bigger ones, for stuff like fog lights.
Old Mar 4, 2006 | 09:04 PM
captin.kid's Avatar
captin.kid
it is the square block one that i have now but is bad i found one but it reads 55w. I will look till i find anouther block style so that i can keep my harness that is installed now.
Old Mar 4, 2006 | 10:26 PM
clong's Avatar
clong
Head over to you local Radio Shack store. Tell the clerk you want a 12v automotive relay. It is a black box relay with a mounting hole at the top. It is rated for 30 amps. Which is 360 Watts.
Old Mar 4, 2006 | 10:33 PM
Howdy's Avatar
Howdy
That's kind of an odd number for a relay. Relays are descibed with volts and amps, and 55W bulbs are really common for fog lights. Wonder if that's a cheap relay for a pair of 55W fog lights? It probably is at least a 25 amp.
Here's a link: http://www.tessco.com/products/displ...&subgroupId=63
Old Mar 5, 2006 | 08:39 AM
cangim's Avatar
cangim
Most places will carry a 30 amp relay. I bought several off of ebay a while back just to have for odd projects here and there. A 30A relay will work great. I wouldn't hook more than 2 lights to one relay, actually I'd probably run each light on its own relay anyway. just my .02
brcwelding
Sep 30, 2012 08:21 AM
bobwhyte2002
May 6, 2012 10:30 PM
Welk49
28
Jan 18, 2009 09:14 PM
captin.kid
Electrical Systems/Wiring
Mar 6, 2006 02:43 PM
captin.kid
2004 - 2008 F150
Mar 4, 2006 10:34 PM
