Starter will not stop cranking
Old Jan 18, 2009 | 09:02 AM
97350's Avatar
97350
I tried to start my truck 2 days ago and my starter would not disengage forcing me to disconnect both batteries to shut it down.after reconnecting them i tried again same thing every time i have checked every fuse i can see nothing seems to be blown.
Old Jan 18, 2009 | 09:13 AM
spazinweasel's Avatar
spazinweasel
sounds like your starter solinoid or ign. switch is stuck
Old Jan 18, 2009 | 09:18 AM
CampSpringsJohn's Avatar
CampSpringsJohn
My money's on the selenoid. I've had it happen before on other vehicles I've owned.
Old Jan 18, 2009 | 09:19 AM
CampSpringsJohn
By the way, welcome to the site! You'll like it here. A lot of information and experience here!
Old Jan 18, 2009 | 09:37 AM
c00nhunterjoe's Avatar
c00nhunterjoe
starter solonoid, happened frequently at the dealer's
Old Jan 18, 2009 | 02:47 PM
97350's Avatar
97350
starter still cranking
wondering if i need to replace starter or if it is a simple thing like a relay or a fuse that needs to be replaced
Old Jan 18, 2009 | 04:12 PM
CampSpringsJohn
You should have a starter relay on the passenger side wheel well. If the problem is in the selenoid, replacing the starter will do no good. On these trucks the selenoid is seperate from the starter.
Old Jan 18, 2009 | 04:46 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Was it cranking really slow, like the batteries were weak?
I have a truck that sits for long periods and the old batts die down. I know when I crank it if it doesn't start up, I need to jump out and unhook the batteries cause it'll keep cranking. All due to low batts. Full charge, no problem.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jan 18, 2009 | 08:38 PM
mike9381150's Avatar
mike9381150
2nd that the older Macks will do the sme thing with low batteries, charge the batteries first and then try it.
Mike
BlackFartF350
Sep 11, 2012 09:05 PM
1985f350
Sep 20, 2006 07:32 PM
1985f350
Sep 20, 2006 07:16 AM
rmckenna
Sep 14, 2006 04:30 PM
MineralStang
1983 - 2012 Ranger & B-Series
Jun 10, 2006 05:57 PM
