Sponsored by: Auxito
Front End Noise?
Old Jan 17, 2009 | 06:35 PM
jonrob's Avatar
jonrob
Front End Noise?
I have a 2003 f150 fx4 with the factory ranchos shocks still on and the truck has just turned 100k. When your driving slow like going over a speed bumb the front end makes a squeaking noise, is it the old shocks or a front susp part?
Old Jan 17, 2009 | 10:16 PM
Ultramagdan's Avatar
Ultramagdan
I doubt it's the shocks. At 100k the front end starts needing a little love.
Old Jan 18, 2009 | 12:12 AM
302w's Avatar
302w
Yeah Im going to agree with ultra, I replaced the front tie arms, control arms, ball joints, and hub bearings at about 110,000 miles. Get your wallet ready because it's going to lighten it up.
Old Jan 18, 2009 | 07:39 PM
bowdog's Avatar
bowdog
Its your ball joints....my truck was doing the same thing....new upper and lower ball joints.......drives like a new truck!!!
Old Jan 19, 2009 | 10:52 AM
ShockGuys's Avatar
ShockGuys
Shocks are a hydraulic cylinder, they don't make noises.
The bushings at the ends of the shocks are rubber, possibly that could squeak. But that would be extremely rare.
More likely it is something else, such as a upper or lower control arm bushing those are rubber too. Springs can sometimes squak against their supports as well (metal on metal).
The only way to know for sure is to inspect all the moving suspension parts on the front end.
Old Jan 19, 2009 | 11:58 PM
metal13x's Avatar
metal13x
Im having the exact same problem. 97 F150 with 103K miles. Every bump makes a very annoying squeak. Also, my pitman arm is doing the same when I steer. The pitman arm squealed really bad a while ago, but i greased it with a needle fitting on my grease gun. It seemed to cure the problem for several months, but the squeek is back. Looks like im going to have to suck it up and just replace the pitman arm. Ill probaby do the upper and lower joints,....and the tie rods.....uhhh, this sucks...
wastingas
Escape & Escape Hybrid
Aug 24, 2013 08:27 AM
cixelsyd
1997 - 2003 F150
Jul 15, 2009 10:00 PM
richartdana44
Jan 16, 2006 07:47 PM
armyman
Nov 1, 2004 11:01 AM
spydermandb
Dec 26, 2001 07:51 PM
