Sponsored by: Auxito
Front End Noise
Old Jul 9, 2009 | 10:03 PM
cixelsyd's Avatar
cixelsyd
Front End Noise
I've isolated the source of my front end noise to either a shock / shock bushing or a stabilizer link.
I've got some new Monroe's on the way as the Truck still has original shocks at 230K and it's due.
The stabilizer link that may be making noise is a TRW replacement that I installed a few years back .. it's all metal with bushings and washers.
It's assembled properly, but is it possible for these to make a squeeking noise over bumps if they are not properly torqued?
Old Jul 10, 2009 | 08:55 PM
galaxie641's Avatar
galaxie641
Are the ball joints original? Mine started squeaking before they went bad. They also went bad at around 240K miles. The only noise I have heard an end link make is a tapping or clanging after they snap in half and they make them while going over bumps.
Old Jul 10, 2009 | 10:15 PM
cixelsyd's Avatar
cixelsyd
Both lowers already replaced, Truck has seen a whole lot of gravel highway travel.
Uppers are original.
Old Jul 11, 2009 | 06:48 AM
n5926g's Avatar
n5926g
Have the uppers replaced.it should correct the noise.
Old Jul 12, 2009 | 11:30 AM
bigun72's Avatar
bigun72
is this referring to the sqeaking noise that sounds like rubber rubbing together when you turn the wheels?
Old Jul 15, 2009 | 10:00 PM
cixelsyd's Avatar
cixelsyd
Problem solved !!
Rubber bushings on all shocks were bad ... especially the top bushings, they were virtually powder. Front right was so bad that the shock could be moved easily by hand - noise was the shock moving around in the mount.
Rides real nice with the new Munroe Gas Magnums, just a little stiffer than the originals. I'm hoping I can get 220K out of the Munroe's also !
jtug69
Jan 23, 2015 07:32 PM
RJCarp2
1978 - 1996 Big Bronco
Apr 11, 2014 01:22 PM
1977F1504X4AUBURN
Dec 19, 2010 07:06 PM
jschoolf
Aug 13, 2009 12:04 PM
sddesigns
Aug 19, 2008 06:37 PM
