Sponsored by: Real Truck
Front End Thump Noise
Old Jan 15, 2006 | 08:25 PM
richartdana44's Avatar
richartdana44
I have an 03 F250 2-wheel drive. The truck has a thumping noise when going over rough pavement. The noise is coming from something in the unsprung weight of the front end. Sounds like a shock has lost it's rubber grommet but this is not the case. I have inspected and tightened everything possible all over the front axle without any success. Has anyone had any experience with this type of noise?
Old Jan 15, 2006 | 08:29 PM
bluev10notpsd's Avatar
bluev10notpsd
I had an 04 that had a tsb for the front leaf spring mounts. The truck was making a thunking noise and they could never figure it out until the tsb came out. Once they replaced the bushings the noise was gone. Now I don't know if this will help you because I think my problem was the factory didn't torque the bolt properly and wore the bushing.
Old Jan 16, 2006 | 07:47 PM
richartdana44
My truck is a 2-wheel drive. It has coil springs not leaf springs and I have already checked to make sure they were seated correctly. I have also checked the sway bar brackets mentioned in other postings without any change.
Steves55
15
Feb 11, 2015 07:18 PM
koboss1
6.4L Power Stroke Diesel
Jul 25, 2011 08:31 PM
modfan
Mar 4, 2008 01:35 AM
WingmanSVT
Feb 15, 2007 12:19 PM
JMACC
Jan 13, 2005 09:09 AM
